The convergence board on my TV went out. It's easily accessible through a front panel, so I pulled it out to check it out.
There's a burnt resistor.
it's light blue, probably about the size of a tic-tac. no color code stripes.
it reads:
1.8OJ (O = ohm symbol)
RNX1
FU 225
I don't know enough about resistors to understand what 1 watt, 3 watt, etc means, or if I should match up the specific size or manufacturer, etc. But I know this should be a 1.8Ohm resistor.
Anyway, I'm trying to tackle this problem myself, it seems to be a common occurence with this JVC projection TV. The board overheats, and usually the chips burn up. I'm hoping I can get by with just replacing this resistor ... so we'll see.
it reads:
RNX1
FU 225
