I'm trying to buy memory for a e4300 box at 266 fsb. Ideally if my fsb is 266 then I need 266mhz memory to get the best performance right? That would be ddr2-533?
Can I buy ddr2-667 or ddr2-800 and still put it in my box and run the same as if I got ddr2-533? I would like my ram to be more "future proof" and if I plan on overclocking the e4300 later on to 400mhz fsb, I would like the ddr2-800 to allow my memory to run 1:1.
I've noticed the timings are higher for the higher speed ram, is there a drawback to this? What do those timings mean? Ithe is it better to get just the lower speed I need to get the perfect timings?
Also, can I buy a 1GB stick of ddr2-667 or 800 from one vendor, then buy the other 1GB stick at a later date and get the dual channel functionality (assuming my board supports it)
BTW....my cpu is a pin-modded e4300 to run at 266mhz on a cheap ECS mobo.
