yallknowho
- Dec 26, 2005
This little program had a host of registry tweaks it could apply to windows XP and let you choose which ones you wanted to install all at once. it was supposed to be run right after a fresh install. options it included were to use WMP 6.4, run ie and explorer as separate processes, and a bunch of other CPU saving tweaks. I can't remember the name, does anyone remember this program? can you point me in the direction to find it? thanks a lot.
