Format _C:
- Jun 12, 2001
The other day I found another LCD Flat Panel TV in the trash
The TV is a Vizio VL370M Of course it does not work but the screen is intact and in excellent condition, The frame is also in excellent condition.
When I plugged it in the Vizio symbol lights up Yellow and when I attempt to power on the TV the Vizio symbol will turn white and the screen will light up and then nothing (No Picture or sound or menus) The TV will stay on in that state until either unplugged or I press the power button again
I have removed the back of the set as I was told on another forum that the main board is bad. I am just double checking with this forum before I order the Main Board.
The numbers on the main board are:
Printed on a sticker
3637-0552-0150(5E)
0KM4049AQ14155E
CSD:3637-0552-0395
Written on the board in white text
0171-2271-2855
All of the boards I saw look the same but I take it I have to order this exact model of board with the same numbers on it for it to work correctly?
Thanks
That's what I posted on another forum but I am now wanting to replace the bad voltage regulators but I am having a tough time finding a replacement part
The bad voltage regulator is marked "L334
G1084"
I also have another regulator marked L7805T (That one is common enough though)
