Happy Hopping
- Jul 1, 2004
http://www.jonsbo.com/products/qiaosiboMOD1hongban.html
so after 7 mth. of delay, I finally have time to drill some holes on the above case. The material is confirmed to be Magnesium Aluminum Alloy.
After spending 45 min., the drill bit won't go thru
the case is Magnesium aluminum alloy. The thickness is 2 mm.
I try a drill bit that says masory, another one say HSS straight shank, and 2 other drill bit. It will make a dent at the beginning. But it won't drill thru the hole
any idea? It should be very straight forward
