W.O.T. Stang
- Aug 4, 2003
Basically I'm trying to share wireless Internet to my desktop PC through a wireless laptop. The wireless router is 2 floors above me, so it's impossible to just connect straight to the wireless router.
Basically it looks like this...
Cable Modem
V
[sisters PC] --- ~Wireless router~
V
~[Wireless Laptop]~
V
Onboard NIC
V
Wired router
V
My desktop PC
Hopefully my terrible network topography made sense. I think the biggest problem i'm running into is that the default IP for the wireless router and my wired router are conflicting. I had to change my wired router to 192.168.1.10 (so i can access both her and my router seperately) and I even set my router to start at 192.168.1.50 so there would be no conflicts in IP between the two.
If I try to use the uplink port in the wired router from the onboard NIC, nothing work.. If I use the port on the router, it drops the internet, but keeps the LAN connection. If I try to bridge the wireless in the laptop to the onboard NIC, nothing works either.
I've got it to the point where I can have Internet on the laptop, or LAN between the two computers, but never both. Can anyone please tell me what i'm overlooking? I'd be greatly appreciative.
Cable Modem
V
V
~[Wireless Laptop]~
V
Onboard NIC
V
Wired router
V
My desktop PC
