micromonkey
- May 16, 2007
Ok so a few days ago I went to Futureshop and picked up a Samsung 226BW. It was the C panel and I ended up bringing it back the next day because of ghosting and some bad backlight bleeding. I replaced it with the LG L226WT. I've been using the L226WT for a couple days now and i find it very annoying because the top half of the screen seems to be darker than the rest, it's only really noticeable when I'm playing World of Warcraft, which I do a lot, also it has worse backlight bleeding than the 226BW. Another thing I have noticed is that the quality of videos with the 226BW and the L226WT is much worse than on my 19" viewsonic CRT that I have used for the last 2.5 years.
Now I'm planning on returning the L226WT and I'm wondering if I should try out the HP W2207 or see if they will open the 226BW's up until I find one with the S Panel, but I'm reading that all these 22" monitors use the TN panels which are very low quality. There are a couple other monitors I'm interested in; the Dell 2407FPW, and possibly the NEC MultiSync 20WMGX2, but after using these 22" lcd's I'm not sure that i want to get anything smaller than that.
If anyone has been in a similar situation or has some helpful advice I would be glad to hear from you.
