Need help choosing between 1080GTX manufacturers!
Discussion in 'Video Cards' started by Massa, Jan 8, 2017.
  1. Massa
    Massa n00bie
    1
    Jan 8, 2017
    Hey guys!
    I am currently in the market for a 1080 after the disappointing CES, and my local shop has both EVGA 1080GTX SC and the MSI Gaming X cards in stock. So basically the question is; which one do you guys think I should get? Overclocking is of minor importance, noise is a big decision factor, and 3 year warranty on both through the shop.
    So, any thoughts?
  2. Comixbooks
    Comixbooks Ignore Me
    10,585
    Jun 7, 2008
    EVGA the fan doesn't spin (zero noise) unless you play a game with ACX 3.0 coolers
  3. MapleSyrupMods
    MapleSyrupMods Bring on Titan X Volta
    1,225
    Oct 3, 2002
    EVGA makes a solid card. My vote goes to them.
  4. NukeDukem
    NukeDukem 2[H]4U
    2,079
    Feb 15, 2011
    Between the two, get the MSI for the custom PCB. The Twin Frozr cooler is whisper quiet and the fans are also off at idle.
  5. Comixbooks
    10,585
    Jun 7, 2008
    I guess the MSI has fans that don't spin either.
  6. KickAssCop
    KickAssCop [H]ardness Supreme
    6,453
    Mar 19, 2003
    Between the two MSI. EVGA really fubared their 10X0 line this time. Too many complaints.
    Another good alternative is ROG STRIX from ASUS. These puppies are also working fine for me for months.
  7. RazorWind
    RazorWind 2[H]4U
    2,982
    Feb 11, 2001
    Unless you plan to water cool, I vote MSI, between those two. EVGA's cooling solution this generation is a little weak, and the MSI card comes with a revised PCB design with more robust power circuitry.
  8. Slystealth
    Slystealth Gawd
    696
    Sep 27, 2010
    MSI all the way , and decently good costumer service! Anything i had trouble with they replaced quickly.. They make great solid cool cards and to be honest , I never hear my GTX 1070 MSI Twin frozr which i would imagine the same design on the 1080
  9. Cr4ckm0nk3y
    Cr4ckm0nk3y Gawd
    754
    Jul 30, 2009
    Between the two mentioned I would go with MSI.
    For the first time since my 260 I moved away from Evga on my NV cards. With the 1080 I went with a Gigabyte G1 and am very pleased with it. It was a toss up between the MSI and GB. The G1 was almost $100 less than the MSI when I was looking so that made the final decision.
    The G1 is very quiet even when the fans run up which is not very often since the card runs cool. At idle the fans turn completely off.
    It lazily OC'd it to the magic 2050 and have never seen the temps go above 70. Most of the time during long game sessions it is in the low 60's.
    But as I previously said, between Evga and MSI take the MSI.
    {NG}Fidel likes this.
  10. Geforcepat
    Geforcepat Gawd
    798
    Jun 2, 2012
    Well as long as it's not evga
  11. GameHard6
    GameHard6 Gawd
    1,004
    Dec 2, 2013
    Personally, I'd go with the MSI GTX 1080 Gaming X. The MSI runs quieter and cooler and also has some nice clocks out of the box. If you go with the EVGA make sure you have one of the updated models that comes with the thermal pads already installed so you don't have to do it yourself.
  12. Starrbuck
    Starrbuck 2[H]4U
    2,236
    Jun 12, 2005
    At this time, I'd avoid EVGA. Any of the other big name brands should be fine. My favorites are Asus >= MSI > Gigabyte. I have a Zotac GTX 970 in one of my son's machines and it's been fine, but I've had mixed experiences with them.
  13. Phlorge
    Phlorge Limp Gawd
    456
    Jun 19, 2014
    if you buy evga its for the warranty and the good customer service
  14. raidflex
    raidflex Limp Gawd
    256
    Dec 12, 2013
    Exactly why I bought my 1080 from EVGA. I have dealt with their support in the past and was very impressed. And as far as I know the thermal pad issue has been resolved anyways.
  15. Phlorge
    Phlorge Limp Gawd
    456
    Jun 19, 2014
    yeah I mean... I was annoyed by the thermal pad thing and ended up just getting a hybrid. but honestly, their customer service has always been good to me so I wasn't mad.
    when I rma'd my reference 980 they ended up sending me an ACX card.
  16. {NG}Fidel
    {NG}Fidel [H]ardness Supreme
    6,146
    Jan 17, 2005
    Evga for warranty. Other brands for cooling performance.
    Starrbuck likes this.
  17. elites2012
    elites2012 n00bie
    20
    Jan 6, 2017
    check every manufacture and look for the one with the longest warranty. thats usually the one that really stands behind their product. ASUS is getting a little weak, i sent in a $20 motherboard i bought on newegg.com. the board went back 6 months in and they emailed me and told me it would cost $160 to fix the board. i left them and went to asrock. i know gpus and motherboards are different, but ASUS inspects and treats both the same.
  18. Starrbuck
    Starrbuck 2[H]4U
    2,236
    Jun 12, 2005
    You should just chunk a $20 motherboard when it breaks. LOL.
  19. caddys83
    caddys83 2[H]4U
    3,264
    Feb 14, 2009
    Pics of said $20 motherboardo_O
  20. bpizzle1
    bpizzle1 2[H]4U
    3,768
    Oct 27, 2007
    I've been turned into a fan of the Zotac Amp! series for video cards. My 980ti from them is like built like a tank, and it runs cool with a massive factory OC. The fans also don't spin below a certain temp (most cards do this now, honestly) if that is a big deal to you. Another bonus is they tend to be a little cheaper due to lack of brand recognition.
Tags:
