This has been bugging me for weeks now! I want to change my Windows partition icon on the OSX desktop and the best walkthrough I can find via the interweb is utterly useless it was seriously written by the mentally handicapped (I added my viewer commentary in bold):
1. Format a USB stick with a FAT file system (you can use any volume really, but it needs to be FAT).
2. In Mac OS X, set a custom volume icon using the Finder's "More info" window or any tool of your choice.
What is exactly meant by "set"?? I can copy and paste the icon file itself, or I can copy the icon's image through Finder but I can't paste this image onto the usb stick!
3. Open a Terminal window, enter "cd /Volumes" and "ls -la". You'll see a file listed that has the same name as the FAT volume, but with a "._" prepended. For example, "._USBSTICK". Copy that file to the equivalent name for the Windows XP NTFS partition, e.g. "cp ._USBSTICK ._WinXP".
Other than being very poorly worded, I'm assuming what is meant by "file" is actually a drive or partition. The "._" is supposed to represent something hidden, so in this step one is supposed to copy a hidden directory/drive to the hidden Windows partition? What gets me is that I do not see the hidden FAT volume nor does it make sense when this step tells you to copy said hidden drive to another non-existent hidden Windows partiton. This step essentially yields no results, nor does it make any sense as Johnny Cochrain would say
4. Transfer the ".VolumeIcon.icns" file created on the FAT file system to the root of the NTFS partition, using Windows.
I'm guessing step 3 needs to have happened for this step to take place. Too bad step 3 DIDNT MAKE ANY SENSE.
With both pieces in place, OS X shows the volume icon on the NTFS partition.
:fips the author of this walthrough and its supporters the universal sign
TIA for any help guys!
