Syphon Filter
- Dec 19, 2003
Gents,
I'm on the cusp of pulling the trigger on a new machine but I cannot decide which GPU to go for.
I will be gaming at 1440p and like to crank up all the settings, bit of a graphics whore I am
I tend to play FPS games, the usual AAA releases and some indie stuff (plus a back-cat of stuff that I need to catch up on).
I'd like something that is going to remain relevant for the next 18-24 months or so as I will probably aim for that sort of upgrade cycle.
Most of the reviews are saying a single card is sufficient for 1440p but it looks marginal to me. Would SLI or Crossfire help maintain higher averages and would the difference be beneficial?
Finally, it seems for now the difference between 3GB and 4GB of VRAM is non-existent. The question is, will it become relevant within my upgrade timeframe? If so then should I really be leaning towards to R9-290X (with the benefit that it's cheaper)?
In the case of the 290X, should I hold out for the non-reference cards? I'm itching to buy but I could show some restraint and hold out until the New Year (which is when people are expecting non-ref cards to land in the UK) if I have to...
So, if you were going to buy now which way would you go?
