IceDigger said:Sounds like this is your first build.
Did you buy a socket 939 cpu on a socket 754 board?
Also the nforce 3 chipset is ancient. They make nforce 4 boards for the 754 chipset now. Also the new socket AM2 boards and cpus are as cheap as the 754 socket stuff.
Autopia said:are you saying that you can put a agp card on a PCI Express board? If not then that is why stayed with a Agp board
Tweakin said:There are plenty of socket 939 motherboards with AGP rather then PCI Express. Also, I get the feeling you think PCI Express means SLI, which is not true. SLI is currently a NVIDIA technology (forgetting old 90's stuff) and boards that support SLI do not demand running in SLI (two cards at once).
As to your original question, of course you can run 32bit windows on the 64bit AMD processors. Those processors are quite a bit older then any public 64bit version of Windows. It would have been pretty silly for AMD to release a line of desktop processors that did not support the currently 90% market share desktop OS.
Though this may not be your first build it is pretty apparent you don't fully understand modern hardware and should probably stop being so defensive about it. People are trying to help you, not mock you.
djnes said:No one said you are dumb, but it is quite obvious that you dove head first into these purchases without doing any reading or research into the terms, compatibility, etc. I'm all for saving money, since I'm old and married as well, but that's even more reason to take your time and know what you are buying. Knowing whether a 64 bit processor can use XP32 or not is a one minute search to get an answer. We're here to help, but you have to be willing to give us the answers to the questions, such as...what exact processor and motherboard did you buy? Post those two bits of info, and then we can keep going.
Autopia said:AMD Athlon 64 3400+ NewCastle Socket 754 CPU
Thermaltake Silent Boost RX K8 CPU Cooling Fan
MB ABIT NF8-V2 NF3-250GB 754
MEM 512Mx2|PQI D400 PQI3200-1024DBH
