Here's the deal, the cable company cut us off last night because my roommate has been downloading files from bittorrent, limewire, and all of the likes. I have explained to him in the past, DO NOT DO THIS, IT IS ILLEGAL! He failed to listen to me, and now our internet connection has been cut off from our ISP. I have tried to block his bittorrent ports in the past on my router (Dlink DIR-655) with no luck. I have googled the ports for Bittorrent and Limewire and have been unable to block those ports. I have tried blocking those ports according to his MAC address (seeing as he change's his IP and computer name often). Here's what I'm looking for. I need a software/hardware solution that will block all ports except for the ones I tell it to leave open. This way when bittorrent does it's scan for open ports (I believe this is called channeling) it will not find any. I need something that will work in a residential environment, and something that I can set without their knowledge. As far as they would be concerned the only thing they could physically do would be to surf the web. If I had my way with them I would only allow port 8080 for them. Please any help would be greatly appreciated!
EDIT: Mod's I hope this is in compliance with this rule (18) You will not discuss, suggest, engage, or encourage any ILLEGAL ACTIVITIES. Links provided to locations that deal with any such activity are also expressly forbidden.
If not then I apologize in advance
