Dapperdan
- Jun 17, 2002
I want to run a FTP server from my home web server. Im using dyndns to get the web server out onto the net. I also use this machine for a VNC server for my company. The OS is windows XP, I didnt set this up Im just running it from my home.
I have a basic ftp service running but as of now its not secured not is there any user accounts setup. This server also only works with the folder "C:\Inetpub\ftproot". Iv already port forwarded 21 for the pc. Iv tried using FTP server software like Filezilla, Serv-U and zFTPServer admin but for what ever reason I cant get them to run.
For example, on Serv-U, Local server says running, but under Domains the server I setup with my info, that wont run. But when I look at the activity log, it says " Wed 08Sep10 00:28:04 - SERVER IS NOT LISTENING ON IP **.***.***.***: Port number 21 already in use!" So I tried forwarding other ports then I get this. "Wed 08Sep10 00:38:26 - SERVER IS NOT LISTENING ON IP **.***.***.**: Trying to use non-existent IP address?"
FileZilla just says "Error could not connect to server"
zFTPServer says "Error: Unable to activate FTP Server on port(s) 21"
So Im lost, I want a secure working FTP server but I also need to make sure it will work with everything else going. It should I dont think there is any real conflicts to worry about. Just no clue what to do now to fix this.
Edit: my router is the Dlink DIR-685
Another thing I need to add, I can access the first server I talked about from my site, ftp:// myhostinginfo.dyndns.org. Thats how I want the FTP to work, access through the site. Ill go with the first option if there is a way to secure it. It would be perfect if I could have one folder public and one private.
