sabregen
- Jun 6, 2005
Looking to possibly mod (and I don't mean loading customer firmware...I mean hardware mod) a Wireless N dual band router. If you have a hardware mod guide that will assist in boosting signal range and quality, I'm all for it. Barring that, I'll do one router on each floor of the house (one upper level - east end, the other lower level west end) as APs.
I'd like to have the ability to run DD-WRT or Tomato on the units. Dual band is required. As I am interested in boosting the signal as far as possible, a guide to hardware modding them, or a unit with standard sized external antennas would also be useful.
Not looking to spend more than $100 per unit (if getting 2x units), or $200 total (whether 2x units, or 1x unit with antenna modifications) to get this working. Units must have the following:
MIMO
3 antennas per frequency (2.4 + 5.0GHz)
Wireless N support DD-WRT or Tomato firmware available
GbE uplink port (yes this ia required)
4x GbE LAN ports (switched)
Any help is appreciated.
MIMO
