Need BIOS settings to run 3.2ghz for E6400 on DQ6 Orthos stable
f1ip
So i can run Windows no problem with 3.2ghz OC. But it fails miserably on Orthos test.
heres CPU-Z, http://valid.x86-secret.com/show_oc.php?id=141475
Orthos ran for a long as 21min. Thats when i increased voltages for Vcore to 1.35 and Vdimm to 2.1v
Memory timings to: 4-4-4-12
It can run SuperPi 32MB fine. and can play games without issues.
Core temps would go as high as 61°C. and processor maxed out at 53°C
CPU: E6400 L631A611 (pack date 11/01/06)
Motherboard: Gigabyte DQ6
Memory: 2GB OCZ Platinum Rev2 PC6400
Air cooled by Thermalright Ultra 120.
whoever has same mobo/cpu/mem running 3.2ghz+ post yer bios settings.
oh yeah, heres my Stable run running 3.096ghz.. pic
f1ip
bah, so i accidentally hit the Delete button when i restarted, so the BIOS came up.. :eek:
went ahead and set FSB to 413 and for the hell of it, put voltage control to Auto. Saved settings, system shut off :(, then restarted normally. :cool:
Now running Orthos for a while now... screenshot
CPU-z - http://valid.x86-secret.com/show_oc?id=142850
ill try manual settings tomorrow..
loxety
Ive got mine running at 3.2ghz 8x400 1.45v seems stable to me, 30c no load, 34c load, 23c room temp
