Hello all,
I have been cutting into my bitfenix prodigy to allow for a 3 slot GPU. Because of this the motherboard will have to be pushed over which I made the necessary cuts for. However, this also means that the mounting holes on a mini ITX board will not line up with the stand offs that pre-exist in the case.
The stand offs were spot welded so they cannot be easily removed and then moved somewhere else. Also, the motherboard will now be resting over two of the holes that would have been previously used for cable management. See here:
So basically I would appreciate some ideas on how to overcome this.
Thanks!
Thanks!
