Operaghost
- Jun 4, 2004
I have an Intel SSD, model: INTEL SSDSA2M080G2GC
Here is a link to the specs page from intel: http://download.intel.com/newsroom/kits/ssd/pdfs/X25-M_34nm_DataSheet.pdf
I have been running Win 7 on this SSD in a multi HDD system for the past few years and haven't had any problems.
I lately got some type of virus that eats up my memory even when idle (csrss.exe, winlogon.exe, nvxdsync.exe, nvvsvc.exe). I've googled these and nowhere can I find a way to remove them. Whatever, worm or trojan it is disabled my Malwarebytes. I tried running a scan on Malwarebytes, NOD32, and Spybot S&D. None of them turned up anything, but I know these aren't the normal processes that exist from windows and Nvidia because I searched and found them in wrong locations, also, they can't be ended and have no description in Task Manager.
However, I digress. So I want to reformat and do a fresh install of Win7 64bit on my intel SSD. I was reading this guide http://www.tweakhound.com/windows7/install7.html
So I started searching the asus sight for updated drivers for my Rampage III Formula.
I found 3 different names of SATA drivers:
1. Intel(R) Rapid Storage Technology Driver Software V10.5.0.1026 for Windows Vista/7 32bit & 64bit.(WHQL)
2. Intel(R) Matrix Storage Manager Driver V8.9.7.1001 for 32/64bit Windows XP & Windows Vista & Windows 7.(WHQL)
3. Marvell 9128 Controller Driver Disk for 32/64bit Windows XP & Windows Vista & Windows 7.
I have no idea which one of these I should use. I'm quite confused with all the host controllers, drivers, SATA types, etc. Its all quite overwhelming. I was hoping you professionals could guide me in the right direction.
