Hello,
What I do:
- I am NOT a gamer (anymore)
- some photoshop
- might one day use programs that need 3D acceleration but not for now, hence the cheap video card (below)
- just want the fastest I can get within my budget
What I already have:
- Processor - Intel i7 920 - 2.66GHz
- Cooling - Noctua NH-U12P - ( link )
- Power - PC Power & Cooling S61EPS 610W - ( link )
- Video - (fanless) SAPPHIRE Radeon HD 4670 - ( link )
- WinXP-32bit for now - Vista-32/64bit later
The goal:
- QUIET, air-cooled i7 system
- STABLE overclock
QUESTIONS:
1. Could you please recommend me a motherboard and memory (3GB or 6GB) combination that will give me a good, absolutely-stable overclock, keeping in mind that:
- I have never done overclocking before
- budget $350-$400 - is this realistic or should I just get more $
- should have room for 3D upgradability later - SLI etc. (I know - I will have to upgrade the power for that)
2. Memory
- if I get 6GB but use 32bit Windows (seeing only 4GB) - would memory performance suffer (only 2 of the 3 sticks being used)?
3. What stable overclock should I expect to get using the cooling above? What settings in BIOS do I have to change in order to get it (for the motherboard you recommend in 1.)?
Any help will be greatly appreciated!!!
What I do:
- some photoshop
The goal:
- STABLE overclock
QUESTIONS:
2. Memory
