Need a way to get dual monitors for my mini
Discussion in 'Apple Products' started by elvis1, Apr 26, 2018.
  1. elvis1
    elvis1 n00bie
    49
    Aug 21, 2010
    Hi guys, after getting a :
    to which I have purchased 16 gb I am planning to have 2 monitors at the same type.
    In latin america Apple stuff is quite rare so I finally got a chance to get some low end stuff ( yes I hope to be able to plunge some SSD's ) but at the time being I need some sort of device I can send as soon as possible AKA amazon ( since my borther does not know how much time he will be asked to remain on east coast).
    I had already spent quite a bit ( for my hardware spendings in an OS I have never ever used ) and would like to have something that .. just works. Any ideas ?
    BTW one of the monitor is old and just has vga and the other one has vga and dvi
    Feedback is very welcomed :)
  2. Archer1212
    Archer1212 SomecallmeTim's Bitch
    9,988
    Jul 5, 2004
    If I remember right that system has Mini-DisplayPort and HDMI for the output on that.
    I would find an HDMI to DVI adapter and a Mini-DP to VGA adapter.
    elvis1 likes this.
  3. AltTabbins
    AltTabbins Muh Feelz Got [H]urt Right in the Pussy
    18,143
    Jul 29, 2005
    I’d honestly look at new monitors as an option. Anything that just has vga probably isn’t even worth using anymore. Even 24” dell 1080p IPS panels are going for less than $150.
  4. elvis1
    elvis1 n00bie
    49
    Aug 21, 2010
    Sadly I would consider such option ( of getting a more suitable display) but as mentioned a couple of mins ago I live in argentina and the US is extremely cheap compared to how they f us.
    I am now making use of a Thunderbolt adapter and works but the image is not precisely neat.
    Ill go and check my reading glasses since I am having a hard time spotting special characters in xcode with this setup
    A friend of mine is trying to find me a suitable connector to make the secondary display work .
    The mini, ram upgrade, swift course, getting proper furniture for my computer and a couple of ssds is Def not something I can afford altogether.
    AltTabbins likes this.
  5. UnknownSouljer
    UnknownSouljer [H]ardness Supreme
    5,713
    Sep 24, 2001
    If it has Thunderbolt, then you can simply use a Display Port to whatever port you need adapter. If VGA, then that. But as has been mentioned, display quality will suffer.
    Using fully digital displays will help you out a lot if you care about quality. I know you can't do it yet, but when you can finally get around to it, it will help a lot.
    EDIT: Ideally you'll want to move to 2x displays that use Displayport, if you want to use the most up-to-date technology that will last you far longer than buying a DVi or VGA display.
    elvis1 likes this.
