wipedout said:So what would be a good 924 chipset board? Decided to go ahead and purchase DDR2 instead.
wipedout said:
What, and my P5GD1 recommendation is chopped liver?wipedout said:
Brav said:I'd recommend the Gigabyte GA-8I915P Duo Pro . Has support for PCI-E, DDR and DDR2. So you can use your current DDR, and upgrade later. Also supports both IDE (2 ports) and SATA for future upgrade.
