Need a modern replacement for a slim line Antec MT-352
Discussion in 'Power Supplies' started by LordJezo, Apr 18, 2019.
  1. LordJezo
    LordJezo Limp Gawd
    467
    Jan 18, 2003
  2. Tsumi
    Tsumi [H]ardForum Junkie
    12,967
    Mar 18, 2010
    Non-standard PSU. You'll have to check to see if Antec made an update for it. If not, you're out of luck.
  3. Grebuloner
    Grebuloner Gawd
    570
    Jul 31, 2009
    The dimensions are very close to the TFX form factor. TFX is longer but narrower than yours. If you aren't opposed to a little ghetto modding to get it to fit, you can get away with one of those easily. Looking at what Newegg is selling, TFX is basically a dead format, only found a couple units above 350W, and none of them are designs newer than about 10 years old. If you really don't mind how it looks, get an SFX PSU, and cut open the case, or just re-case the system. Perhaps in a cardboard box. ;)
    Now, if your PSU is otherwise functioning well and you're really more interested in supporting your drives, get a Molex to SATA adapter. Costs a few bucks, works just fine.
    pendragon1 likes this.
  4. Jorona
    Jorona 2[H]4U
    3,276
    Nov 6, 2011
