didnt try that but a found something that works pretty well thnxs buddy
Well...it's working, but taking FOREVER. Seems to be using just over 30% CPU usage. I need something that uses all 4 cores and the video card.
Does it take that long for you too?
Badaboom took 20 minutes and looked better. They've yet to update it for fermi tho.
If u look close, you'll see a picture of a disc in the upper left corner.
Audio's never been a problem for me cause I only shrink for phone and netbook.
Ah, it wasn't clear from your first post.That's for the source, not the output. It can take video from a DVD but not create a DVD
Absolutely nothing.That's fine for you. But what about the op?
