Right now i am using the PC150's from Sennheiser and although they sound ok when i use them, the mic is kinda crappy. Since it is directional your mouth pretty much has be be facing it perfectly for it to be loud and clear. 75% of the time i wear them around my neck and use the mic with my speakers which makes the mic suck even more. Is there a better headset out there that would work well for me, or would it be best to get a good headphone and a mic seperate?
My other problem is my new watercooling radiator hangs right over the back of my computer making it really hard to get back there and swap from my speakers to my headset. Is there any way to have them both work at the same time, or any way to select one over another rather than having to get my hand cut up by my fan while trying to swap out a dang sound jack?
