Need 10" laptop with Ethernet, SSD
Discussion in 'Mobile Computing' started by Happy Hopping, Apr 8, 2015.
  1. Happy Hopping
    Happy Hopping [H]ardness Supreme
    6,394
    Jul 1, 2004
    I have visited a no. of brand name site on 10" laptop, none of them have RJ-45 on it. My portable is a Lenovo w/ Win xP. Now, I want a same size notebook that has a small SSD and RJ-45 on it. Can anyone recommend a brand name?
  2. Chris_Lonardo
    Chris_Lonardo [H]ard|OCP Storage Engineer & Editor
    1,726
    Feb 10, 2002
    Unfortunately, RJ45 jacks are getting more and more rare these days. 10" notebooks are pretty rare as well- there are plenty of 10" 2-in-1's (none of which have RJ45 jacks), and plenty of notebooks in the 11.6" class.
    Acer has a few that could fit the bill if you can deal with the 11.6" screen. Since you didn't really say what you needed, here's a cheap one, but they're available in myriad configurations- http://www.newegg.com/Product/Product.aspx?Item=N82E16834314645
    If it has an HDD, well.. you can always pull it out and replace it with a 2.5" SSD, it's not like it's much of a waste with the price of HDDs these days.
  3. FnordMan
    FnordMan [H]ard|Gawd
    1,734
    Apr 22, 2011
    Best you can do nowadays is finding the right form factor that has a full size usb port and getting a usb ethernet controller.
    There's the Surface 3 but I doubt that one's upgradable.
    Dell has the Venue 11 line which you can upgrade the SSD in but not the memory. (you can in the pro at least, both the core i models and the core m ones)
    There's plenty of other 10" 2 in 1's as mentioned above though.
    We kinda need more info and an idea of how much you want to spend on it.
  4. Erasmus354
    Erasmus354 [H]ardForum Junkie
    9,463
    Mar 12, 2004
    Just get a USB3 to Ethernet dongle, they work pretty well.
    Also consider looking at some of the 13" ultrabooks. The Dell XPS13 is incredibly small for a 13" machine.
  5. Happy Hopping
    6,394
    Jul 1, 2004
    The amt. of $ spent doesn't really matter.
    I use a 10" that fits vertically in my brief case. I only use this to test if there is internet connection at client's site. So w/o a RJ-45 port, I don't know what to do. Is SUB to Ethernet dongle workable or is there some sort of draw back on it?
    even so, 11.6" is too big and heavy to carry it in a brief case. As the brief case is heavy enough
  6. FnordMan
    1,734
    Apr 22, 2011
    define: "Drawback" you plug it in, you plug in ethernet cable, done. (you might need an internet connection for drivers initially)
  7. heatlesssun
    heatlesssun Stay [H]ard
    44,263
    Nov 5, 2005
    The Surface 3 might be the device for you if money isn't an issue but size is. The Surface 3 with the Type Cover is only two pounds but you'll need an USB to Ethernet adapter. It is 10.8" and not 10.1" but you can check the dimensions on the spec sheet or even try it out at a store, Microsoft Stores and I think Best Buys now have them on display.
  8. jimh425
    jimh425 Gawd
    645
    Jan 7, 2012
    Asus netbooks had a ethernet jack. Asus 11.6 models frequently do as well.
  9. Happy Hopping
    6,394
    Jul 1, 2004
    see my screen is 10", when you add the corner, it's 12". And that's the max. size of the brief case, to slide in vertical. I suppose I can slide in horizontal, but that's the last course of action
    so when you people said 10.8", you are really talking about 1 + 1 + 10.8" = 12.8"
  10. Happy Hopping
    6,394
    Jul 1, 2004
    unexpected hiccups. Do you people have any brand name in mind? There are the ones w/ the wire, like this 1:
    http://www.newegg.com/Product/Produ...sb_to_ethernet_adapter-_-33-114-120-_-Product
    and there are ones w/o the wire, and that is usually a better idea so no wire can be damage
    http://www.newegg.com/Product/Produ...sb_to_ethernet_adapter-_-12-200-741-_-Product
    if there is no hiccups, I think the Surface 3 will do, it's light enough
    for those who own Surface 1, 2, how many year does your model last? Is it Li Ion battery?
    http://www.microsoft.com/surface/en-us/support/surface-2-specs
    AS Mr. gates decides to hide the kind of battery they use
    and any chance to downgrade to Win 7, and still get touch screen and all the drivers?
  11. 0ptional
    0ptional Don't Trust Your Friends with Your Decanter
    5,604
    Feb 22, 2003
  12. heatlesssun
    44,263
    Nov 5, 2005
    It's doable on the Surface Pro models. The Surface 3 will be a little trickier because Cherry Trail and prior Atom SoCs don't have official Windows 7 support. If touch is at all a major consideration, and for a device like a Surface 3 that's very likely, I don't think Windows 7 makes a lot of sense. The difference wouldn't be that big if one were to only use desktop apps but again, with something like a Surface 3 modern apps make a lot of sense when using touch.
    While Windows 8 may not make a lot of sense to many with only keyboard and mouse operation, it's make a LOT more sense on a hybrid device.
  13. heatlesssun
    44,263
    Nov 5, 2005
  14. FnordMan
    1,734
    Apr 22, 2011
    Personally i'd suggest one with a wire as it'll put less stress on the usb port.
    Do note that the surface 3 has usb 3.0 so you can get a gigabit adapter if you want.
    Far as brands go i'm not sure if it matters a whole lot given that there's a really good chance they're going to be using similar realtek chips in there. Just look for one with good reviews i'd say.
  15. NeoMatriX724
    NeoMatriX724 Limp Gawd
    269
    Jul 26, 2007
    I just got the Dell XPS 13 a few days ago. It's 12inches on the longest edge. Pretty darn tiny and light. The lack of bezel on the monitor is really much more impressive than i thought.
    dvsman likes this.
  16. cyclone3d
    cyclone3d [H]ardForum Junkie
    12,682
    Aug 16, 2004
    You need to also check the overall dimensions of the models you are looking at. The border around the screens has gotten a decent amount smaller in the last few years.
  17. Happy Hopping
    6,394
    Jul 1, 2004
  18. cyclone3d
    12,682
    Aug 16, 2004
    Taken directly from their site under the tech specs tab.
    Dimensions & Weight7
    Width: 11.85” / 301mm
    Height: .90“ / 22.9mm
    Depth: 8.35” / 212mm
    Starting weight: 2.98lbs / 1.35kg
    Why are you assuming that the display bezel always adds 2 inches to the width of the device?
  19. -Dragon-
    -Dragon- 2[H]4U
    2,320
    Apr 6, 2007
    If the width is 11.85" it can't possibly be 11.6" including bezel
    Go go Pythagoreans' theorum:
    sqrt(11.85*11.85 + 8.35*8.35) = 14.49"
    Which is more than 1" bezels and much larger than the SP3
    The Surface 3 is probably the best bet for around 10" since most 10" devices have a 16:9 aspect ration where the S3 is 3:2 like its big brother, so it's likely about as wide as any other 10" device but with a little added depth.
  20. Happy Hopping
    6,394
    Jul 1, 2004
    excellent pt. I forgot win 8 is design to make pc users get use to nokia phone, so microsoft can sell more nokia windows phone
    I can just wait for win 10
  21. Happy Hopping
    6,394
    Jul 1, 2004
    it doesn't matter in that case.
    My current sub notebook is 1.6" thick, because the battery is at an angle (stupid design by lenovo), but 1.2 KG. Or 2.5 lb (it feels heavier). I'm trying to cut weight and thickness on a new laptop. If the above 2.98 lb., that's actually heavier, so I'll pass
  22. Happy Hopping
    6,394
    Jul 1, 2004
    Can you open the Surface and upgrade to a bigger mSATA in the future?
    And what kind of battery is it, does anyone knows? If not, how many times can you charge the battery? 500 times? 1000 times?
  23. -Dragon-
    -Dragon- 2[H]4U
    2,320
    Apr 6, 2007
    No surface is what you'd call remotely user servicable. They're some sort of lithium ion, while the original surface and surface 2's didn't have great battery life to start with I've not heard any rash of complaints about it getting significantly worse after 2 or 3 years so I guess whatever they are is sufficient
  24. Happy Hopping
    6,394
    Jul 1, 2004
    as long as there is 500 to 600+ charges, then it's okay
  25. Erasmus354
    9,463
    Mar 12, 2004
    get the Surface 3, your stated needs are small, light, and can verify network connections. The Surface 3 is going to be the best build quality, smallest, and lightest machine that can do what you want it to do. Get a USB3 Gigabit adapter, you will be good to go.
  26. Chas
    Chas [H]ardness Supreme
    6,140
    Oct 31, 2005
  27. Happy Hopping
    6,394
    Jul 1, 2004
    I never have a chance to buy a new laptop, until now, my criteria remains unchanged:
    10" screen
    0.88 KG
    Li Ion battery
    Win 10
    1" thin or less
    very good quality
    Have said the above, is Microsoft Surface (older models) the only ones out there?
  28. heatlesssun
    44,263
    Nov 5, 2005
    So it has to be 10"?
  29. Happy Hopping
    6,394
    Jul 1, 2004
    it fits in my brief case vertically. I have been using a Lenovo notebook 10" for 19 year. It really works. So far, I can only find older Microsoft surface in that screen size. Is there other brand? I'm happy w/ microsoft, but I wonder if there are other brands that is good quality
  30. heatlesssun
    44,263
    Nov 5, 2005
    Most of the Windows tablets that size are Atom based, which aren't necessarily bad but they can chug. Something with a Core M and real SSD drive will run much better but most of those are around 12". What's in your Lenovo?
  31. Happy Hopping
    6,394
    Jul 1, 2004
    photoshop cs2, microsoft office, adobe writer, the usual, nothing fancy.
  32. heatlesssun
    44,263
    Nov 5, 2005
    Sorry if I wasn't clear, I meant hardware specs, CPU, RAM, etc. You mentioned PS so I think you'd be much happier with a Core M or better.
  33. Happy Hopping
    6,394
    Jul 1, 2004
    CS2 can run on Petium 3 or 4 as per their spec.
    I'm using 4 GB of RAM, Intel Atom CPU, 100 GB hard drive.
  34. Grentz
    Grentz Stay [H]ard
    17,150
    May 5, 2006
    You need to look at device dimensions not the screen dimensions.
    The old 10" netbook I have is bigger than many larger screen devices today.
  35. Happy Hopping
    6,394
    Jul 1, 2004
    the exact diagonal measurement is 10". I did see Microsoft surface 3 is at 10.6", and if there is no other brand smaller than 10.6", I'll go w/ microsoft
  36. YeuEmMaiMai
    YeuEmMaiMai Death Incarnate
    12,410
    Jun 11, 2004
    if I needed Ethernet I would use the dock that came with the tablet.. as that DOES have a gigabit Ethernet port.
  37. SticKx911
    SticKx911 [H]ard|Gawd
    1,996
    Mar 14, 2004
    I had the exact same requirements recently and settled with an older aspire one d255. It's slow as fuck, but it has the needed size/features to do its job.
    as for new, they do not exist. There's a british brand that makes a really good 10" one, but you'll need a usb>rj45 adapter.
  38. Happy Hopping
    6,394
    Jul 1, 2004
    that's a 3rd party generic brand name, I'll stick w/ major brand with legitimate R&D, such as HP, Dell, Lenovo (IBM) or Microsoft
    Does anyone knows the approx. charge time of a MS Surface 3?
  39. tom_ozahoski
    tom_ozahoski Limp Gawd
    207
    Feb 24, 2014
    Forget the screen size and go by the chassis size. What is the diagonal size of your current machine?
    My wife's surface 3 charges in under 3 hours from dead and last all day, 8+ hours.
