HeadHunter
- Dec 2, 2007
I tried it again with 35% contrast. While some of the color ghosting was reduced with greys, if i move around the hardforum page i get green ghosts where the red borders the grey (ghost moves from the red to the grey), and the white text develops an inverse ghost trail. The same happened after i dropped my brightness to 60% as well.
I use this monitor in bright light most of the time so I require high brightness/contrast settings.
I'm a bit confused as to the conflicting reports of ghosting since they said they never changed the lcd panel in these displays. Can some people just not notice it or are some displays not exhibiting this "Feature"?
Even with factory default settings I get ghosting on the hardforum page. The posting page I'm on right now moving up develops a light band at the top of the grey border, and a green band where the red borders the grey if i move it down. The text (yellow and white) also develops a purple/black trail.
My piece does have the same problem, but I wouldn't notice that if you didn't tell me.
I think/thought it's normal for even this class of panel...
But if its not, its another reason to RMA.
also something else I noticed...
its SLOWWWWWW.
i just installed vista on my girls pc which has a CRT and a TN panel.
I sat back down at my computer and the lag was awful. its about double the latency of my gateway 24" pva.
Well, read what I've written recently...I didn't try to RMA it yet, but you should try it...
Or you are sensitive to lag as well.
When first powered, the unit is pretty dull but after what seems like 5-15 minutes, it reaches peak brightness. Are any others experiencing this warm-up period?
Same here...
