NEC 2490WUXi - The Full Story
Discussion in 'Displays' started by albovin, Feb 23, 2009.
  1. psyside
    psyside 2[H]4U
    2,243
    Apr 23, 2009
    Wow thanks albovin your are really helpful person ;) what i dont understand now
    is does that profiler software calibrate the monitor lut or the graphic card?
    like you said the colorimeter is not included in the package if the software is
    capable to make calibration of the (monitor lut not the video card) its maybe
    worth but if does not then i really dont know for that they charge double
    price :eek: it would be no logical cause someone said that basiccolor4 is
    much better then spectraview2 so if its like that software only is better then
    software and hardware for 250 $ more or you get sofware only for 700 euros
    more realy confusing ? sorry for not understanding but as i said before noob here
    im new with the monitors and stuff,thanks and again sorry for disturbing.
  2. psyside
    psyside 2[H]4U
    2,243
    Apr 23, 2009
    Almost forgot to ask, someone said that the software is aviable to download at Nec
    site 15 days trail version does that version offer the same options like the software
    that comes with the monitor or its difrent ?
  3. mlewis
    mlewis Limp Gawd
    283
    May 19, 2008
    The EU Spectraview Profiler software will hardware calibrate EU Spectraview monitors. It will not hardware calibrate non Spectraview monitors. The software trial available on the NEC site is the same as the software that comes with the Spectraview monitors.
  4. psyside
    psyside 2[H]4U
    2,243
    Apr 23, 2009
    Hehe glad to hear that,thanks for the info.Looks like there is no need to buy the sv version?
    i can just use the trial version? what will i miss if i dont buy the sv model and use only
    the trial version (guess i can use it more then one time if i donwnload from other ip) or im
    wrong ? Cause for EU you dont get hardware calibrator (colorimeter) anyway if you buy the( spectraview
    model) so they charge 700 euros for software only damn thats insane :confused:
    Even if that monitors are handpicked hard to believe that its worth.
  5. Postmodum
    Postmodum Limp Gawd
    169
    Nov 29, 2004
    So, at this moment i have a doubt and today i almost bought the 2690WXUi-2 ...
    in your opinion, what's the best option ... WXUi or the WXUi-2 ?
    This monitor will be used for lots of graphic work... some gaming :)
    Btw, is it necessary 2 dvi connections for this monitor?
  6. psyside
    psyside 2[H]4U
    2,243
    Apr 23, 2009
    Wuxi2 does not have polarizer the old version has it i would recomend to get the wuxi
    cause of that no doubt better choice.
  7. Postmodum
    Postmodum Limp Gawd
    169
    Nov 29, 2004
    i'll be facing the monitor , there won't be any angle problem, so the polarizer will not be a great plus for this situation :)
  8. _HU_
    _HU_ [H]Lite
    125
    Oct 21, 2008
    Thanks very much for your reply. I don't want to "fight" again with the man of the service center. I had to do many calls (about 8, no kidding) about the quality issues of my old 2690 and I don't want to repeat that "awful experience".
    I'd like to know if anyone from Europe (apart of me) is suffering this issue... I can't believe I'm the only one (apart the case you told me before) which see these waves, only on gray backgrounds. With my old 2690 the situation was worse; I saw the waves both in gray and blue backgrounds... I think it's a power supply issue. May be the circuits used to convert from 110V (north american voltage) to 220V (european voltage) are a crap (unforgivable on a monitor of this range).
    I tried enabling DDR Spread Spectrum hidden feature, according to an user, and it makes no difference.
    Do you think that tuning the service menu I could to decrease the issue? If yes, how can I enable the service menu?
    Thank you again
  9. albovin
    albovin [H]ard|Gawd
    1,653
    Feb 16, 2008
    Deleted by poster
  10. _HU_
    _HU_ [H]Lite
    125
    Oct 21, 2008
    Thanks albovin for your support.
    The case is I've had a 2690 with the same defect (not exactly, it was worse) than the 2490, and I'm so tired to talk the service center... This unit has no dead pixels nor dead subpixels, so I'll wait some time before using the warranty (3 years on Europe). It's a lottery to get a NEC monitor without dead pixels. Believe me, I've had 3 replacements for my old 2690 with dead pixels/subpixels (three as maximum) and a "purple blur" in one of them. I'm sorry but I have to say quality control at NEC sucks.
    Kind regards and keep up your superb reviews ;)
  11. maury
    maury n00b
    6
    May 9, 2009
    Just wondering if anyone has tried this yet...buy a 2490 or 2690 and tried to run spectraview software to calibrate it...it would help to know if NEC europe truly did block this as a possible option...I mean it seems to me the distributors in europe, or whomever is responsible for the price gouging, are just asking for people to try and bypass the 'normal' buying route...what a shame...I don't think anyone minds paying for product but come on, doubling the price of display prices for calibration software and a puck?...
    hey albovin...thanks for the great write up on the 2490...it's either this or the 2690 this week for me...kind regards...
    M
  12. albovin
    albovin [H]ard|Gawd
    1,653
    Feb 16, 2008
    Deleted by poster
  13. xorbe
    xorbe [H]ardness Supreme
    6,023
    Sep 26, 2008
    My 2490 SV has 1 slight wave on the right side, fwiw.
  14. psyside
    psyside 2[H]4U
    2,243
    Apr 23, 2009
    Is it possible to buy spectraview kit in EU? if its not any suggestion how to get it?
    thanks to all helpful guys on this forum ;)
    EDIT: Any one knows where can i buy/order Nec2490-SV in Eu?
    it seems that the price was double only in Germany,for the sv version
    so please inform me if any one knows
    thanks in advance.
  15. mlewis
    mlewis Limp Gawd
    283
    May 19, 2008
    You will need somwone in the US to buy it for you and send it to you.
  16. psyside
    psyside 2[H]4U
    2,243
    Apr 23, 2009
    hehe Mlewis as always, you deserve medal for all this information many thanks ;)
    also maybe you can answer me about the edit part thanks alot!
  17. maury
    maury n00b
    6
    May 9, 2009
    you can download sv ll off the usa NEC site : then all you need is for your friend in the usa to email the serial number...
  18. _HU_
    _HU_ [H]Lite
    125
    Oct 21, 2008
    Are you an european user? I have the same issue, but located on the left side (on my 2490 and on my old 2690 too), I only see the waves on middle gray backgrounds... Can you explain in more detail your problem? Thanks
    PS: I have written a PM to Will Hollingworth (Monitor Guy on this forum), product manager of NEC Display of America. I hope he explain this issue that we are suffering some european users.
  19. psyside
    psyside 2[H]4U
    2,243
    Apr 23, 2009
    Maury,
    Hmm nice one, but is it possible to use that software on long term as far as i know
    its trail version (15 days) don't know can you use it again by deleting/reinstall option?
    if its like that then i can have Nec 2490-SV very fast ;) thanks for the suggestion.
  20. Biges
    Biges [H]ard|Gawd
    1,475
    Feb 28, 2008
    Just use google, people. Or spend money to buy the full version of the calibration software, afaik basICColor display will also perform the full hardware calibration.
  21. psyside
    psyside 2[H]4U
    2,243
    Apr 23, 2009
    Yes i guess i will get the sv version if its available the price difrence was not double as i tought i found 2690-SV for only 300$ more then the regular model guess that means
    the 2490 price will be decent.
    offtopic:
    Any one knows why subscribed threads options (Quick links) ain't work?
    also the messages i sent are not in the "outbox" it show 0
  22. mike82y
    mike82y [H]Lite
    102
    Jun 27, 2007
    is this monitor for gaming also?
  23. psyside
    psyside 2[H]4U
    2,243
    Apr 23, 2009
    Yes it is its the best monitor overall only slight input lag but in every aspect the monitor
    is perfect! but if you ask me ill forget about that "lag" and buy it instant!
  24. Malakai
    Malakai 2[H]4U
    2,124
    Dec 29, 2001
    "Serious machine for serious men"
    :LOL:
    My G2400WD is better for gaming ;)
  25. _HU_
    _HU_ [H]Lite
    125
    Oct 21, 2008
    Are you kidding? The BenQ G2400WD is a TN panel, and the 2490WUXi is an H-IPS panel with 6ms grey-to-grey response. A TN panel is always worse than a IPS panel in every aspect. And I'm sure that the 2490WUXi with its 8ms of response is FASTER than a 2ms TN panel. In addition, the 2490WUXi has the better scaler in the market, with options not found in other monitors. You can see games in full splendor and without black bars on ANY resolution (with its superb interpolation algorithm, NO loss on sharpness details). These are FACTS. However, the 2490WUXi is not affordable and is suitable for professionals. It's quite adequate for gaming, but it isn't its primary use.
  26. nomu
    nomu Gawd
    818
    Jul 30, 2006
    The G/V2400W/WD/WT all have good scalers, and they are faster than the 2490 even without overdrive. They're also less laggy. So as a single-purpose monitor using only human performance as the deciding criteria, the G2400W family are better gaming monitors. However, that's only if you're using PC FPS to decide, otherwise the BenQ has no advantages except price.
  27. albovin
    albovin [H]ard|Gawd
    1,653
    Feb 16, 2008
    Deleted by poster
  28. SD45
    SD45 Limp Gawd
    164
    Jan 4, 2009
    Jeez. Does any of this matter, other than to those who are personally adding to global warming?
  29. mike_j_johnson
    mike_j_johnson Gawd
    961
    Nov 13, 2004
  30. maury
    maury n00b
    6
    May 9, 2009
    oh boy...thanks for the heads up albovin...ideas?...they'll trash the polarizer, add some buttons, charge more money?...maybe a wide gamut version?...upgraded panel?...lordy lordy...
  31. Malakai
    Malakai 2[H]4U
    2,124
    Dec 29, 2001
    Very wrong. There are several advantages TNs have over other tech types, one of the majors being price.
    I could go on but you are obviously not interested in any facts.
    Each tech type has its strengths and weaknesses. If one type was the hands down best there would be no need for others, no one would buy them. Interestingly TNs are by far the most prevalent LCD type. Those markets, always favoring totally useless subpar tech, doh!
  32. _HU_
    _HU_ [H]Lite
    125
    Oct 21, 2008
    Apart of the "advantage" of reduced price and may be better black level (surpassed by PVA technology)... which those advantages are? OK, the price is an important factor, specially on crysis times, but even that disadvantage is vanishing... Now, we have the HP LP2475w with H-IPS panel at an affordable price and the new DELL 2209WA with e-IPS panel with the price of a medium TN panel. And soon we'll have the new LG IPS panels for the mainstream (not only for professionals) at a reasonable price.
    Come on, I would like to hear them (I've already said 2 disadvantages over TN technology, so please don't comment them again). And the input lag is not inherent to the IPS nature, but the image processing performed by the monitor. In fact, there are IPS monitors with 0ms of input lag (LG W2600HP). The NEC 2490WUXi has average input lag due to the complex image processing which performs.
    Of course! TN technology is the most prevalent for its price and its low cost of manufacturing. But IPS technology is the more "balanced" technology, i.e., it's the technology with less faults. Believe or not, TN is the worst technology among the 3 known panels: IPS, PVA, TN. Probably albovin could illustrate you with these facts (not myths).
  33. Forceman
    Forceman [H]ardForum Junkie
    9,243
    Aug 7, 2005
    Your statement was too definitive - a TN panel is always worse than an IPS in every aspect. Malakai pointed out one area where TN is not always worse, price. Another is input lag. You can discount the importance of those two all you like, but you can't really expect anyone to listen to you say that those things don't ever matter for anyone.
    Sure TN is the inferior technology, but that hasn't stopped it from being the dominant panel type (by sales volume). To ignore that fact is pretty disingenuous.
  34. nomu
    nomu Gawd
    818
    Jul 30, 2006
    TNs don't actually have any advantage in input lag. That's simply a matter of what price points the lagless monitors come in at. There are laggy TN at all price points, but the two lagless models are much cheaper than the lagless IPS (possibly excepting the Doublesight 265W.) And of course the least laggy *VA is the 24WMGX3, but neither that NEC nor the 265W could be considered well-rounded models.
    Other than that, yes TNs do have price, and sort of response time. The most striking thing is that you can't have it all with non-TNs: you can't get a fast, responsive IPS/VA with deep blacks, and you definitely can't have all that for a low price. You've got to give up something, and the easiest one to drop is input lag.
  35. xorbe
    6,023
    Sep 26, 2008
    2490wuxi2 -- my bet, they'll ride on the 2490wuxi's great reputation while making it cheaper to produce, somehow...
  36. Postmodum
    Postmodum Limp Gawd
    169
    Nov 29, 2004
    the weird part is that the price different between the 24 and the 26 isn't that big ...
  37. _HU_
    _HU_ [H]Lite
    125
    Oct 21, 2008
  38. Postmodum
    Postmodum Limp Gawd
    169
    Nov 29, 2004
    Hmmmm... i'm interested in that problem too ...
    I'm to buy the LCD2690WUXi-2 ... that "wavy effect" is only in gradients?
  39. Biges
    Biges [H]ard|Gawd
    1,475
    Feb 28, 2008
    Well, BenQ G2400WD surely has a lowe input lag than NEC 2490. And some people are versy sensitive to higher input lag, so the only choice for them is a fast TN monitor. I don't mind the lag myself :)
