Hi guys, I'm thinking between this and the HP LP2475w as well. I'm leaning toward the NEC for now, but I have a few things I want to know.
How bad is e-IPS really is compared to other IPS? what about compared to PVA? (I have a 24" Acer PVA pannel.)
Also, I read in the spec that it support 24-bit colors, is this actually referring to windows' 32-bit color? (as I read that 32-bit true color is actually 24-bit +other filter thing) I don't want to buy something that producese less color than my current monitor.....
Thx for the input, but can anyone answer me about the 24-bit color? can I set 32-not in windows with this monitor? if so I'm going to buy this one
Hi all.
Anyway, I was wondering if anyone has tested the difference between DVI and Displayport on this NEC monitor yet? I'm using it with a Displayport 1.1 cable and a workstation card (ATI FirePro v8700), but haven't had any extra time yet to test the differences between the two.
Thanks!
I am interested in this as well, since my current videocard has no DP output.
Jan.
Congrats ! ! !
Ill give you some tips that could of saved me a ton of time
Put on dynamic setting so the eco garbage get's turned off if left on it will change your monitor to match brightness of scene , every time I opened up Google my desktop would get bleached out , then when i closed the screen would get dark
I set my brightness to 19 - 21 and my contrast to 50 but had to use windows calibrate for gamma and color to get the greenish out but came str8 really easy
after I put side to side with my 20wmgx playing a movie in the middle , the new one looked way better ?
Hi all.
{snip}
Hopefully this is useful for someone. I don't have a CRT or measurement device, so I can't do any tests with such instruments.
I would recommend this monitor for people who like quality colors and minimal lag at a good price.
Just about to buy one of these but before I do could somebody please answer this question. .
What is the best quality way to plug in a Nintendo Wii into this monitor and what is the cheapest way?
My Philips LX1000 will be using the DVI socket leaving the VGA and Display port available.
Will these cables work for the cheap way?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=400062415298&ssPageName=STRK:MEWAX:IT
http://cgi.ebay.co.uk/PLAYSTATION-3...s_VideoGameAccessories_JN?hash=item439bad168b
Is it possible to get a HD Signal on my Wii with this monitor?
Thank you
Those cables only work when the TV / Monitor can accept Component signals over the VGA port. Normally, VGA passes RGBHV, not Component. According to a post by ToastyX, this monitor will not accept Component over the VGA input. You would have to buy an active Component -> VGA box which can go for $50-$100 (usually including a cable). Note that Component -> VGA and VGA -> Component devices are not the same, but some of the more expensive converters work in both directions.
Portrait or landscape?
Is buy.com a NEC authorized seller? I know NEC only has warranty on those units sold by their authorized seller.
I once had a NEC LCD monitor bought from overstock.com. When I requested a warranty service from NEC (they did asked for purchase receipt), I was told overstock is not NEC authorized reseller and they refused warranty coverage because of that.Why would the selling vendor or even a second hand monitor change the warranty ? I didn't see any terms about the seller on NECs site, got a link?
