rogue_jedi
- Sep 6, 2002
Well, I dislike the tyan p3 board I have currently in my fileserver... lots of little quirks that make it pretty much a POS. Plus only 2 64-bit PCI slots (and no other expansion slots) makes it unsuited for what I want to do with it - hard to get 13 hard drives and gigE out of 2 slots. (2x supermicro 8 port sata cards and a dual port broadcom gigE nic) So, I'm looking at my options. I'm considering dual xeon boards, and these two caught my eye. The X5DL8 is a Serverworks Grand Champion-LE chipset board, with 6 pci-x slots and 4 pci-x buses and other good stuff like that. However, the only information about people actually using it (from google search) is that it is slow, as compared to other xeon boards.
The NCCH-DL is based on 875p and thus doesn't support registered memory. It also only has 2 pci-x slots, but it has standard PCI slots too and I could get away with that (I think).
I'm probably going to put a pair of 1.6LV xeons (or whatever I can get cheap) in this, as I don't need much power - but if I got the NCCH-DL I'd be tempted to put a 9700pro in it and get a kvm.
So, basically... has anyone actually used the X5DL8? Is it any good? I've heard good things about the NCCH-DL as a gaming system/workstation but nothing about it for a server. Are there any other recommendations for this application (available cheaply, preferably - I don't want to spend more than $200 on this, and the less I have to spend the better)
Thanks.
the black knight always triumphs!
Thanks.
