Speadyjooce
- Jun 4, 2016
yeah cause gravity will pull the fluid down and into the pump and loop. once there's fluid in the pump power it up and keep filling. no damage unless it runs dry. the two pics you posted show different fill methods. the black/gold would have to sit on its front panel so fluid will flow to the pump. not sure if they used the t or the top of the pump... the clear one would sit upright and fill through that silver tube with the biohazard sign.
Thanks for your help.
