rumartinez89
- Apr 16, 2012
Vortez has a review on it but they dont compare the tundra to the h80 only the h100. The build quality seems nice though.
The connection points do not pivot.
How much height clearance is there between the GPU (with a full-cover water block) and the case floor?
Do you think it would be possible to fit a 1.5" thick Laing DDC-1T Plus pump and a 1.5" thick Swiftech MCRES Micro Rev2 reservoir in the space below the GPU?
They're waiting on a production unit from Lian-Li to ensure everything is correct.
Hey Everyone,
Been following / reading through this thread for a while now, just wanted to get some opinions from some more experienced builders here. This is my first time building a mITX build in such a small space and had some questions regarding heat.
I saw the thermal/noise testing but it didn't cover the exact scenario I wanted to attempt.
The build:
- ASUS P8Z77-I
- 2600k with stock cooler
- HD6870 reference blower cooler
- 1 SSD / 1 3.5" HDD
- 2x GT AP-11(500 rpm) or AP-12 (800rpm) mounted on the side
- SilverStone ST45SF-G (noiseblocker mod)
Would this number of fans be sufficient enough cooling for this size case? If not any input would be great.
Any particular suggestions of a good quiet cooler that fits that dimension + a fan? I've never had a huge problem with the stock cooler so I've never bothered replacing it![]()
That review is so far below amateur it's not even funny anymore. He is talking about RAM clearance as if the radiator is always placed in relation to the motherboard. No noise test just that it's "somewhat loud" at 100%. For some reason, he thinks a passive test is something relevant to an i7-3930K.
I'll wait for a decent review.
The only thing worth mentioning is this:
I was going to pass over this case because Frankly I was never really all that thrilled with the design decisions that were made. The SG-05 had always been enough for me but I always wanted it to be aluminum. That and I always wished that I could easily move the PSU to the front of the chasis which is obviously what is going on with this case. So if costs can be kept down I may have to break down and buy one of these since I have always wanted an aluminum SG-05 and this is about as close as one can get.
If they had moved the PSU, I would have bought it already. Also as far as I can tell, it's still a steel frame which seems silly.There's always the FT03 mini. It's basically the SG05, just with the face pointing down. Not to my tastes personally, but it could be an option if you haven't looked into it.
Great, thx for the update ! While you are at it, the Tundra TD02 needs a review and I hear this site has a good reviewerThat's a mistake actually, the connection point to the CPU block does pivot. I'll check with him to correct it!
Guys, Silverstone listened to us, and updated the 450W SFX gold psu:
http://hardforum.com/showthread.php?p=1040030333&posted=1#post1040030333
It seems that new V2.0 version is more silent at low loads, which is precisely what we asked for.
Honestly, i would have much preferred a new SFX PSU instead. 80+ platinum, passive, modular.
Hey, I did get your PMs (both of them). The production campaign will be open to everyone, so no worries about getting one.Hey guys, just found out about the amazing case today, anyone know of any possible ways to still sign up for it?
np.Ah, sorry about that lol. I couldn't make sure it went through when I checked the sent messages so I sent another one to confirm.
We've been in 'soon' status for a while now. But the preproduction sample is currently in shipping, and assuming everything looks good when I inspect it, we should be pretty much good to go for the campaign.When will the production campaign be opening? I noticed that you're early shipment campaigns were already finished (congrats on reaching the goal).
Sounds great, do you have any approximate dates on when the campaign will begin and when the cases would start shipping thereafter?
Great, thx for the update ! While you are at it, the Tundra TD02 needs a review and I hear this site has a good reviewer![]()
