So good news first, the D9L cooler fits on the ASRock Z270 M-ITX Fatal1ty board with Vengeance LPX memory.
Bad news...my board won't turn on. The light on the power switch won't even come on. With all of these silent fans, I can't even be certain my PSU works.
Any suggestions where to start?
Would Corsair Dominator Platinum be out of the quest for this board?
Is there any way to test the PSU itself?
What is the height of that memory?
Search online and you should find photos and videos of how to test that the power supply can at least turn on. Here is the first one I found:
http://marcomiltenburg.com/2011/09/18/how-to-test-an-atx-power-supply/
This will involve jumpering two of the wires in the 24-pin motherboard connector. The power supply should not be connected to anything except a case fan. The wires to connect are the PS_ON# wire and a Common Ground (COM) wire. It is harder to identify which wires are which when they are all black so study the photos and videos carefully. After the two wires are connected by a U-shaped wire or paper clip, turn on the power supply's rocker switch. The power supply should make an audible click and the fans should spin. The PS fan may stop because of the low load and cool temperature of the PS , but the case fan should be spinning.
Be careful and good luck!
I'm not sure exactly what you're asking...
- If it is "WHERE" the keycaps are, then they're located on the outside of the keyboard. The entire top row and all the keys with double printed for functions are original. The tab, caps, shift, ctrl space etc around the edges, arrow keys and pg up/down are gradient
- If it's "WHAT" the keycaps are, then look here or here for an explanation. Double shot means the keys are made from two plastic types. The printing on the keys is actually part of the keycap. In this case, a clear plastic on the inside to let the backlight through and a second hard plastic for the casing.
Finally, I bought mine from ebay as there is a definite lack of supply in Australia. But if you use your Google Fu, you'll find plenty of US retailers.
I don't have an adapter for the case fan unfortunately - I'm going to pick up one this weekend. I also ordered a new PSU from amazon and an internal speaker. Is the click and spin true for the SF450 series?
Yes. I used a SF450 on my son's M1 build. His SF450 is plugged into his Asus Z170I Pro Gaming inside the M1 right now, but here is the start up sequence and the sounds I hear from the power supply when starting with no charge in the power supply:
Start up:
Shutdown before Windows starts:
- Start with the power supply's rocker switch in the OFF position.
- Connect power supply to an electrical outlet.
- Put rocker switch in the ON position. No sounds have been heard from the power supply up to this point.
- Press the case's power switch once or short the power switch pins on the motherboard momentarily. At this exact moment a click is heard from the power supply. The power supply fan spins for less than 1 second and then stops due to the low load and low temperature.
- After about 4 seconds a single short beep is heard from the motherboard indicating a good POST (Power On Self Test). You will not hear this when the power supply is not connected to the motherboard.
If I put the rocker into the OFF position before Windows loads I hear a click right at the moment the switch is set to OFF. About 4 seconds later I hear a second click. About 4 more seconds later I hear a third click.
Shutdown from Windows:
When I use the Start Menu to shutdown a single click is hear after about 5 seconds, once the computer has completed shutting down. If I now put the rocker switch to the OFF position and then press the case power switch once I hear a click at the moment I pressed the switch (from within the power supply) and then a few seconds later I hear another click.
I got a click and the fan spun briefly when I shorted the 24-pin motherboard connector. When I connect everything to the motherboard, and try shorting the Power and Ground pins, nothing happens.
I have a PSU tester that came from Amazon. Used it a couple of times on questionable power supplies, very handy when you need it. $15 for the one I use.Well at least you didn't blow up your power supply! OK, until you get a speaker connected to the motherboard, there's not much you can do except check that the CPU is inserted with the correct orientation and that none of the pins in the CPU socket are bent. Just be very careful to lift the CPU vertically to make sure you don't damage the pins underneath.
Another idea would be to find a friend or a local computer repair shop that would test your PS, CPU and RAM with another motherboard.
Does anyone else have a suggestion?
Speaker arrives on Monday, I'll report back then. If I don't get any beeps, I'll send the mobo back. I started the ASRock RMA process - unfortunately neither ASRock nor Newegg have any in stock. I'm going to keep a close eye on other retailers. Any recommenations other than Amazon for the U.S.?
You can mount one 3.5" HDD or two 2.5" HDDs on the floor of the case, but not both. There are the inside/outside chassis front for mounting the 2.5" HDDs though, at least one of which should be available depending what else you're fitting in.Can you stick a 3.5 inch drive and 2 2.5 inch HDDs in the base the NCASE?
Will there be clearance for all the sata and sata power cables?
Thanks
Yes, but it depends on the rest of your hardware.
The drive cage can holder two 3.5-inch drives (or 1 drive and a 120 mm fan, I think) and it can be mounted on either half of the side bracket or on the case floor. This will depend on the CPU cooler size or graphics card length.
A 3.5-inch drive can also be mounted directly to the case floor at the rear. This position may limit airflow to the graphics card or cause the drive to get hot due to heat from the card.
Two 2.5-inch drives can be mounted to the outside of the front panel (both 7 mm drives), to the inside of the front panel (both drives 9 mm or less), or to the case floor through the use of the stacking brackets. Alternatively, a single 15 mm thick drive (up to 4 TB now) can be mounted to either side of the front panel (or to the case floor).
If you don't want to drill and tap to a larger size, you can maybe use a threaded-insert or maybe even a thread repair set (Heli-coil). All of these require a bit of tooling (sometimes included). The simplest solution may just be to drill it out and use a nut, you could maybe glue the nut in place.Does anyone know how to fix stripped threads? the threads in one of the holes on the back of the case got stripped. I have been enjoying my case for years now, but I finally (excuse the pun) screwed up and cross threaded one of the screws in the hole where you put the screw to fasten the side bracket on the back. I suppose I could just buy a tap to make new threads in the same hole, thereby making the hole larger and then use a larger screw, but I would prefer to use the original screws. Is there a better way to fix it?
http://www.outletpc.com/jf4207-asro...l_krLQ5Jt9UXBR4UWCQ1p0pCszuzHD10D0aAgvE8P8HAQ
Outlet PC lists them in stock.
Well, no, my plans are: (Already have both of them built)You are not going to be able to fit an ATX PSU and water cooled graphics card in the ncase, and have it quiet too. I am on my second attempt at getting my build done, and to have top tier components (7700k + GTX 1080) reasonably quiet you need to fit two 240 radiators in the case. This isn't possible with ATX PSU. That said my SFX Corsair SF450 has so far been very quiet even with ~250 Watt load, so it is possible to get quiet SFX PSU's.
Personally I think there is only one good option in such a small case, video cards with rear exhaust.Anyone tried a ZOTAC GeForce® GTX 1070 Mini in the NCASE M1?
https://www.zotac.com/gb/product/graphics_card/zotac-geforce®-gtx-1070-mini-0#spec
And would this fit if I am currently using 2 x 3.5" hard drives with the hard drive cage at the side?
The one on the left is my old build, there was plenty of room to fit 2x 3.5" drives and a 120mm rad with an R9 290.I did a search and found a few builds that had the drive cage on the front half of the side bracket with two 3.5-inch drives and a graphics card below that was longer than the Zotac 1070 Mini. Here are two such photos from the NCASE M1 User Build Gallery on Imgur:
https://www.newegg.com/Product/Product.aspx?Item=N82E16813132954 I know a lot of people have been waiting for the Asus Strix Z270, Newegg lists them in stock but you better hurry.
Just picked one up, thanks rfarmer!
