NCASE M1: a crowdfunded Mini-ITX case (updates in first post)
Discussion in 'Small Form Factor Systems' started by wahaha360, Sep 15, 2012.
  1. CHANG3D
    CHANG3D [H]ardness Supreme
    4,769
    Jul 23, 2010
    It really could be. But then again, NVidia recommends a minimum system requirement of 500W. So Silverstone probably won't help me in any way. I'll gladly have you experts look at my system if you are in my neighborhood.
    Currently I basically "hot-swap" by unplugging one and plugging in the other. I just cannot go with three drives without a lot of crashing.
    And yes, I know my PSU is not the 80+ Gold one, but rather the Silver one.
  2. cookiePlant
    cookiePlant n00b
    58
    Apr 8, 2013
    I showed up here because I did a lot of research on the available ITX cases and nothing can compare with this one :) (cubitek minicube is pretty cool though).Theres a difference between making harmless inquiries and disparaging the product / asking for it to change. On another note this case is gonna cost 300+ dollars for people overseas and it wouldn't make much sense for them to buy a GPU thats worth the same amount as the case :p. I think thats the reason why so many people on this thread are talking about placing very expensive hardware in their M1.
  3. wreckem
    wreckem [H]Lite
    113
    Nov 12, 2011
    Personally I am going put as high end stuff as I can afford because this is likely my last build unless things change drastically, namely the the place Intel and others plan to take the desktop hardware market.
  4. balance101
    balance101 Limp Gawd
    411
    Jan 31, 2008
    thats what I tell myself but if you keep coming to hardforum you will be tempted..
  5. Phuncz
    Phuncz 2[H]4U
    2,630
    Apr 12, 2009
    Why not get a workstation laptop ? Those are actually meant to be lugged around and can fit in your backpack or overhead compartment.
  6. Zangmonkey
    Zangmonkey I Realize My Disabilities - You Do Too
    3,627
    Jul 6, 2005
    I think Jeff Atwood is really on-point when it comes to specific-purpose design... while his blog is about software in particular I think it applies as easily here as it did to the Pontiac Aztec
    http://www.codinghorror.com/blog/20...ty-but-dont-let-them-tell-you-what-to-do.html
  7. Diverge
    Diverge Gawd
    536
    Nov 22, 2005
    Mechanical hard drives use a decent amount of power (in comparison to their idle and usage power) to spool up during boots. Some bioses have options to stagger the drives so they spool up in series rather than parallel.
  8. Phuncz
    Phuncz 2[H]4U
    2,630
    Apr 12, 2009
    Luckily at that point your GPU and CPU aren't at 100% load.
  9. Morac
    Morac n00b
    39
    Nov 28, 2012
    Fortunately GPUs tend not to be running at max capacity during boot-up sequences.
    EDIT: Damn, beaten to the snark.
  10. M4rk
    M4rk Gawd
    999
    Nov 30, 2005
    Necere and W360 have done an admirable job of staying "on-mission" even while accommodating some suggestions from early posters in this thread. Back then the thread was short and easy to read through (I found it when it was around 15 pages long, maybe more, and read through it all in an hour or two at work). Now that the thread is over 100 pages, reading it completely is a bit of an undertaking. Consequently we have people appearing that think the case has already been sold out, or that it's still in planning, or it should be able to accommodate an mATX mobo. :rolleyes:
    I'm cool with that, though. Someone normally clears up the misunderstanding and we keep trucking along.
  11. ekuest
    ekuest [H]ardness Supreme
    6,091
    Feb 23, 2009
    it's actually bronze. :p
  12. Zangmonkey
    3,627
    Jul 6, 2005
    I agree. They've done great.
    I was mostly responding to the mounting pressure to "add this" and "change that" which is a certainty as the word gets out on a neat project.
    Also, I always try to take the opportunity to spread CodingHorror :D
  13. crABtoad
    crABtoad Limp Gawd
    508
    May 15, 2012
    The whole project has been a smashing success to date. You can't please everyone, and they've done a great job of cramming options into a very small case. It's the only case I've found to date that seem to be able to replace my excellent SG05. Since that was it's original purpose... Necere and W360 have done an excellent job of bouncing ideas off of each other, and the community, and have solidified it into a tangible item.
  14. CHANG3D
    4,769
    Jul 23, 2010
    Sorry, forgot about it.
    But, yes, the computer crashes as the disks (or disk while the other was the ssd) start to spin.
  15. CHANG3D
    4,769
    Jul 23, 2010
    I can't wait to get one of these and repurpose my Prodigy. The handle bars are annoying when moving. I like need to wear a glove for it.
  16. M4rk
    M4rk Gawd
    999
    Nov 30, 2005
    You'll probably still want to wear gloves when handling the M1, if just to keep your human grease off the beautiful aluminum.
    Mmm, non-stick human grease.
  17. *Daedalus
    *Daedalus [H]Lite
    107
    Jan 6, 2011
    It'a anodised, so shouldn't leave fingerprints. :)
  18. Phuncz
    Phuncz 2[H]4U
    2,630
    Apr 12, 2009
    You should have a talk with my Lian-Li black anodised case. He doesn't agree with you.
  19. faugusztin
    faugusztin 2[H]4U
    2,653
    Mar 9, 2008
    I have yet to ever see a Lian Li case which doesn't contain (nearly) irremovable fingerprints. PC-A09B, PC-A17B, PC-V1000B, PC-V1110A, PC-Q08B, PC-Q09R - all have fingerprints, maybe except PC-Q09R which is red and the fingerprints are hard to see. Everything else has them.
  20. *Daedalus
    *Daedalus [H]Lite
    107
    Jan 6, 2011
    Well damn. I had always thought that anodising was supposed to help quite a lot with fingerprints. An old laptop of mine had an anodised aluminium shell and didn't pick up anything at all.
  21. crABtoad
    crABtoad Limp Gawd
    508
    May 15, 2012
    The only information I could find on short notice was that the oil from skin will etch/oxidize non-anodized alu cases, and that fingerprints will become part of the surface over time. Anodized don't do this apparently. You would need some kinda of hard, oil-repellent surface to completely avoid fingerprinting... I think.
    @Necere, W360: Any ETA on the case prototype? Gettin' antsy. :D
  22. Necere
    Necere 2[H]4U
    2,729
    Jan 3, 2003
    Prototype shipped this morning from Taiwan.
  23. Volkswagen
    Volkswagen Moderator Staff Member
    4,774
    Nov 12, 2002
    Thats HOT :D
  24. crABtoad
    crABtoad Limp Gawd
    508
    May 15, 2012
    I think I just over-gasped.
  25. medeyer
    medeyer Limp Gawd
    355
    Jan 16, 2013
    Guess you're going to have a fun weekend.
  26. Necere
    Necere 2[H]4U
    2,729
    Jan 3, 2003
    Possibly, but not because of the case :p It won't arrive until next week.
  27. Dephcon
    Dephcon [H]ard|Gawd
    1,234
    Jul 27, 2004
    [​IMG]
  28. CMadki4
    CMadki4 [H]ardness Supreme
    4,438
    Feb 3, 2011
    Necere/Wahaha360: How did Lian Li approach the slot for the optical drive? Did they do a felt insert or brush of some sort?
  29. M4rk
    M4rk Gawd
    999
    Nov 30, 2005
    Maximum overgasp.
  30. iakovl
    iakovl [H]Lite
    104
    Nov 12, 2008
    drool... nothing more nothing less
    WE DEMAND PIC's!!!
  31. Phuncz
    Phuncz 2[H]4U
    2,630
    Apr 12, 2009
    Slotloading drives should have those, not the slots in front of them.
    http://i.imgur.com/SvAJCep.jpg
  32. Zangmonkey
    3,627
    Jul 6, 2005
  33. crABtoad
    crABtoad Limp Gawd
    508
    May 15, 2012
    Do you have any testimonials? I can't seem to find any information for this site. Seems sketchy to me, but I'm not on the design crew end.
  34. Solvik89
    Solvik89 n00b
    2
    Apr 12, 2013
    Damn i whant this.
    Is it possible too buy this ? I saw that i was too late to donate.
    would that mean, that i cant buy one of these ?
  35. Not yet. The first crowdfunding campaign was to pay for the prototypes, and there will be a second campaign that will be the one to pay directly for the case.
    Just keep this post in favorites, and you will know when this happens ;)
  36. Solvik89
    Solvik89 n00b
    2
    Apr 12, 2013
    Thanks for the quick reply.
    No doubt about, that I will buy this case! This is the baddest I have seen in a long time!
    I never thought of getting me a such a small case, but after I saw this, it is possible and high performance machine, but still small case! Love it!
  37. Moogles
    Moogles [H]Lite
    69
    Jul 26, 2007
    Just noticed the prototype doesn't have the round metal feet. Will they be absent from the retail version, too?
  38. *Daedalus
    *Daedalus [H]Lite
    107
    Jan 6, 2011
    No, the retail version will have feet. Lian-Li just didn't have them in when they took the pictures.
  39. Diverge
    Diverge Gawd
    536
    Nov 22, 2005
    Did the prototype get delivered yet? :)
  40. Zangmonkey
    3,627
    Jul 6, 2005
    TAIWAN Y U SO FAR AWAY?!
