That àn impressive build.
Could you please share info about the total cost? May be create a pcpart picker ?I am Still confuse about how Much it cos to go the watercooled way.
Also could you share some temps and benchmark info?
My only recommendation will be to have the PSU to Mother board power câble not in front of the tube but on the back of it. Except that it s à flawless build that show why the M1 is so impressive.
Do you think a thicker one would fit in any of the other orientations?thanks, it is good looking, my old nexus5 camera dont do it justice. No, 25mm fan will not fit, not even a 20mm, you can probably fit a 15mm fan though, the noctua nf-a9x14 pwm fits and leaves you with 1 or 2 mm before touching the heatpipes with my orientation which I think is the best for this configuration.
Preliminarily, I ran the Heaven benchmark and Prime95 simultaneously for an hour--but the attached monitor was a small spare with only 1440 x 900 resolution. I'll test later with a 1920 x 1200 resolution monitor. The results were as follows:
CPU: Maximum: 87 C . . . Average: 69 C
GPU: Maximum: 60 C . . . Average: 54 C
I have the C7. Goti to ff Amazon. I'm not overclocked, but I like the C7 for the size as well as the look as well as the performance. It's not the absolute best in keeping the CPU cool, but it's really really fine for the job. If you ever used a Coolermaster Hyper 212, then I say this is the equivalent in a sff case form.
Good to hear, but what's noise like with the C7? I've heard it can get rather loud in certain situations, which is understandable considering the 92mm fan.
Like this? NCase M1 Buildyou could have the heatpipes facing down and fit a 25mm fan in the rear but that forbids installing a gpu.
there should be some space around your bottom fans for some wires and the other side of your psu, thats where I hide most of mine
yes but it's still a mess, the original wires that come with the psu are too long. can anyone tell me how long the wires have to be if I wanna order them online like some of you guys did? cause if I wanna measure them now I would have to take everything apart again...
Gandergray What about the noise level of the pump and the fan? Over all systèm noise?
Your temps are quite good
Thanks à lot for the vidéo. Hard to get an idea of the actual noise but at least we can for sure say that it s noticeable.
Now that during à benchmark... so worst scénario.
How do you feel about the noise? Still acceptable or very noticeable?
I'm not sure how to "objectively" describe sound. So, if you care to listen, this is a video (shot with an iPhone SE) of the fan and pump noise from the subject computer 21278. At the time, it was simultaneously running the Heaven benchmark at 1440 x 900 resolution and Prime95 for the purpose of leak testing--thus, the absence of panels. The upper radiator fan, a Scythe Slip Stream 120 SY1225SL12M, was running at about 1,100 rpms. The two fans on the bottom radiator, Prolimatech Ultra Sleek Vortex 12s (PWM), were running at about 1,300. After a half hour of running (computer at maximum temperature and holding), temperatures were as follows: CPU--Max--87C--Ave--72C, GPU--Max--61C--Ave--59C. (Ambient: 24.2C)
As I note in the video description, you may have to turn up the volume and listen in a quiet place to get a better sense of the sound and the pitch or tonal quality. To contrast the sound with "nothing", listen to the final portion of the video, and then, of course, the absence of sound after the video ends.
Thanks for the reply, I did think about that but considering I sold mine off already i was looking for perhaps a stronger top-down solution that may work better as my VRMs get very hot. If I knew the TF would fit 100% with no issues I'd likely just jump on that, as the U9S is also now hardish to find XD. And costs only 10 bucks less than the TF. Add another fan and that increases costs a lot for the U9S(can re use a u9b se2 fan though i guess?). Based on the compatibility list it SHOULD work with my Z87i-Pro given it works with the Z170 Impact, but a few mm makes all the difference ><.i think your best bet is to get the u9s with another fan, as many reviews put it near the dark rock tf in performance.
Wonder if same as the Asus Z170I Pro Gaming w/ Corsair SF600...For those of you interested in custom cables for these components:
- MB: Gigabyte GA‑Z170N‑Gaming 5
- PSU: Silverstone SFX-600W
- GPU: GTX1080 Founders Edition
Here are the lengths I went with:
- 24 Pin ATX 300 mm
- 4+4 Pin EPS 300 mm
- Dual Molex 150 mm + 50 mm
- Dual SATA Power 150 mm + 50 mm
- 8 Pin PCI-E 150 mm (I would recommend slightly longer than 150mm, so that the cable can be more easily routed under the video card to reduce pressure on the card)
Based on image search on both motherboards, the 24 pin and 4+4 pin connectors are in similar locations. It really depends on how you'd want to route your cables.Wonder if same as the Asus Z170I Pro Gaming w/ Corsair SF600...
if dark rock tf and u9s is not a go, may I suggest the noctua c14 and the cryorig M9i
edit: never mind you already looked at those options. How are the return policy in aus like? I know most will allow returns if one does not peel off the heatsink stickers, I say use u9b se2 for now and return dark rock tf if it doesn't fit.
Does anyone have pics of this case with mixed color panels? I remember seeing them posted a while ago, but can't seem to find them.
Hi all,
Been a while since I posted here. I admittedly swapped out of my Ncase M1 for a Thermaltake F1 for 'ease of use' for a short while and want to go back. I have a Noctua U9B SE-2 in storage to go back into the Ncase when I do a swap shortly. However, I'm really interested in something more powerful given I run everything low RPM to keep noises down, and will be upgrading to a 1070 soon from a lowly GTX 750 Ti while I get back into gaming. Currently i5 4690k at 1.15v at 4.2ghz. I live in Aus so any higher (even as we've just started spring) already starts shooting up temps.
I wanted the Noctua C-14 original but nowhere local appears to have it. There is - Be Quiet Dark Rock TF however i've read some potential issues with this fitting.. I own the Asus Z87i-Pro with daughterboard. Ideally I'd like this to fit with heatpipes facing the rear but I understand this may not work... Alternatively - Cryorig M9i or Be Quiet! Pure Rock Slim or Cryorig C1 are alternatives but I don't think they'd gain me much over the U9B SE-2 (I have owned a U9S but when I swapped cases I sold this.. eh).
Can anyone comment perhaps on what would be a solid choice? I'm fine with the dark rock if it'll fit no problems but the sheet states 'only one orientation' and not sure if it'll interfere with my motherboard.
Ideally I'd really prefer the C14, as i'd install 2 fans on the side, have no under fan, gives me room to move around a little internally etc, but it's either sold out or not listed anymore. (One places says in stock, but i went there 'no stock all gone'. still says in stock online -.-).
Thanks!
PS: Edit, the C14s is still plausible if the low profile option works? using the fan under...
Located in AusA quick Google search shows NE having three Noctua C-14 still in stock. $99 though but if you want best hsf cooling I would say it's worth it. If that's too rich for you just get a U9S.
Located in Aus. The AUS version of NE does not have stock sadly.
Oh, sorry about that. Can you get your hands on a U9S? That's probably the closest you'll get to max cooling (using air) after the C14. People have used AIO units but the tubes can be tricky to coil without kinking but some have had success with them. Because this is such a small case I would say stick with air hsf units. We know they work and they are less troublesome to install. Just my own opinion of course.
Tkaing off the plastic makes me so nervous about shorting out the video cardI would like to post an update fpr people considering the bequite dark rock TF as a cpu cooler for their M1 build.
The compatibilty spread sheet says, it will not fit because of interference with ram and PCIe slot with most motherboards except the Gigabyte z170n gaming 5, which is really hard to get at the moment.
So I tried my luck with the asus z170i, all prepared for having to use a riser for the graphics card and this is the result: Ncase M1 bequite Dark Rock TF on Asus Z170i pro gaming (mini-itx) motherboard
Interference with ram can be confirmed but is easily remedied (if you are willing to "damage" a cooler with that kind of price tag).
I took off the the bottom "teeth" of the bottom heat sink, so that it would not push on to the ram stick. First I clipped them off with a side cutter and filed them down to get them more even and take away the sharp edges.
Temps so far are good. The i5 6600k @4,5 turbo sits at 34°C at idle and around 60 at full load.
The main surprise was though, that I could fit the gfx card without the riser. Even with the aluminium caps at the end of the headpipes the card would fit. One just touched one screw without applying any downward pressure to the card.
With the caps off, you get even a little more space, so a backplated card might fit in as well. I was not able to test that though.
Ooooh someone who has the tf in exact position that i want to have it with a motherboard that has all of the major components in the same position as mine. Tell me son, how much room is there between the heatsink and the back intake? Can one fit a fan that is thicker than 15mm? I hope that my calculations were incorrect or that the pictures that i made them using were made from a perspective that could mislead me. ThanksI would like to post an update fpr people considering the bequite dark rock TF as a cpu cooler for their M1 build.
They might be metal, but they're most likely aluminum so there should be no chance of shorting out, since aluminum is non-conductive. If you take the black caps off however, the heatpipes are most likely copper, which as we all know is a highly conductive metal, both in terms of heat and power, this however does not mean that even if it were to be touching any of the exposed contact points on the back of the card, like for example a simple smd cap that it would short it out.Those black caps are metal too? That's even more risky
Was indeed referring to anodized aluminum since the top and the caps do look like they're anodized. That being said though i just took a look at the spec sheet for the cooler and it's just simply brushed aluminum so my whole point is invalid.All metal is electrically conductive, though anodized aluminum is not. Perhaps this is what you were referring to. If removing the caps allows a non-conductive backplate to added to the graphics card, then that is what I'd do.
