Nope. Conflicts with the PSU. Shuttle boards are long and narrow - something like 280mm deep. Using an SFX PSU you're limited to mini-ITX - 170mm deep; with ATX, ~200mm.Wonder if a SZ77R5 mobo will fit in here
The whole case is aluminum, including the part the front I/O sit in.so is the whole case alu? Parts of the usb thing looked plastic in the front. Will you offer a plain unpainted one for those of us modders who dont want to sand it down just to repaint it?
Doesn't help. The difference in width between SFX and ATX is only 25mm, which isn't enough to clear the RAM on a Shuttle board.What about a SFX in an ATX adapter plate (so it's rotated sideways) -- especially an adapter plate that moved it as close to the radiator exclusion area as possible?
We're not planning on including an adapter plate. Someone mentioned that the SilverStone SFXs come with one, though.One of those will be included, AFAIK.
Many system builders lack this common sense planning mentality, at least that's my impression judging by the threads I read (here and on other forums). I believe it would be pretty smart to put a big statement on the Kickstarter page saying parts that exceed standard size limitations may not fit inside the case. This way Necere and W360 don't have to apologize to anyone who purchased components that don't fit.I think with this case more hardware will fit than hardware that won't fit. Necere clearly said graphic cards don't fit that don't conform the "PCI-express card electromechanical specification", which are luckily exceptions, not the general rule.
He also said, and I'm putting this in bright pink letters because this can't be stressed enough:
Proper planning is crucial to a successful build in this (and any) small case.
I have a Lian-Li PC-V352 and being a rather large mATX case, it has VERY specific demands for some of the hardware, although touting large numbers aplenty.
- Graphics card: power connectors need to be at the side of the card, not the top or at a specific location on the top. If you look at this picture, you see where the red SATA cables are wedged between the PSU and optical drive cage, if your power connectors are EXACTLY there, it might work. But I guarantee you, you'll hate it when they have to come out. Also the cooler can't be ANY bigger than the PCI-express card specs or it won't fit.
- PSU: I had to find a shorter-than-normal one or it wouldn't be possible to fit. And it still is a tight fit, I need to disassemble almost everything just to reach a hard disk.
- CPU heatsink: frustratingly it's blocked by, and this happens a lot in this case, a piece of the case itself, that's there MAYBE for structural rigidity. Otherwise I could have actually mounted a fan on it.
I just wish ASUS didn't have that silly daughter board on all their mITX motherboards.
It's useful if you wanted to get a >140mm long or modular ATX power supply in the case for whatever reason (noise, already have it).I am so excited for this mini-build with the M1 case!
Not sure this matter since this will support a full-length GPU, but I'm excited for this:
http://www.slashgear.com/odd-looking-asus-geforce-gtx-670-directcu-mini-video-card-debuts-03276270/
[/url]
They're expecting the feet on Monday and then it will be ready to ship.(Five minutes later)
Is it here yet?????
We're going to try to get a Swiftech H220 for testing dual rad support (if it ever stays in stock long enough for us to grab one). It's 13 FPI, which is about as low as you'll find on a slim rad. The fans it comes with are also PWM, so running at a range of speeds shouldn't be a problem.Something I'd like to mention just so it's there:
I'm going to go out on a limb and assume a CPU+GPU+240 rad is on the agenda for testing. I'd really appreciate it if you could get some decent fans (Gentle Typhoons, preferably) and when temperature testing, start at very low RPM (I don't know exactly what mine are running at, but they're 1150RPM fans, running at 7V). I try to make all my builds as silent as possible, so I need to know if temperatures will be even within reason at those sorts of speeds.
Of course this means you'll need a decent low-speed rad. Something like an Alphacool NexXxoS or XSPC EX240 would be ideal.
Huh. I was under the impression that apart from the change to a single 8-pin and minor changes to the power circuitry it was essentially the same as the reference PCB. Guess not.http://i.imgur.com/37RzoEO.jpg
http://i.imgur.com/P2bNmsm.jpg
(Asus GTX670 Mini)
NOOOOOOOOOOOOO !!! Why is it wider/higher
I hope we can confirm that it fits, otherwise I'll have to manufacture an L-shaped connector.
I won't be doing serious sound testing a la SPCR; it's out of scope for our testing, and I doubt the noise floor where I'm at is low enough in any case.
With the stock D5 housing, there's no chance of getting it inside with a dual rad. It's just too big. With an aftermarket top on the D5 it's possible to mount the pump at the bottom front, so long as you're using a short card (e.g., GTX670 w/waterblock).Oh, and I wouldn't mind seeing if a D5 can be fit in there (and actually connected in a loop. Tube routing, etc.)
There's ~140mm from the surface of the motherboard to the fan bracket, so figure ~132mm after subtracting the CPU socket height.Do we have an estimate of how tall of a cpu air cooler can be used?
Just estimating, it looks like 120mm if there is no fan installed in the rear side mount.
I am not eager to install liquid cooling, and will sacrifice some top end Overclock.
This seems totally pointless to me. You don't need any review based on this case to know how well (or bad) a 240 rad will cool X components. What you should know is that if you plan to run a silent build (1150rpm fans at 7V seems like 600rpm to me), watercooling the gpu and cpu at 600rpm is simply IMPOSSIBLE if you plan to put any stress on your system... unless you are talking about low-end components. It will never work (and I'm not even talking about overclock).
Regarding to watercool the components... your best (and probably only one) bet would be to include a cpu block with integrated pump and, still, the housing would have to be placed somewhere, and it would cause a massive hindrance to fill, bleed and everything. I'm starting to think that the best thing will be to have the radiator external with some quick-disconnects and be done with it. You will get a much better performance, too.
I ran an i5-750 and 5770 on 2 120mm radiators with 2 1200 rpm fans @~700rpm just fine. Never got over ~50*C (~25*C amb) during every stress test I could throw at it. Granted those aren't really high power components, but even with a mild OC it was very usable and very cool running. If I wanted to go back to the PITA of custom water, I'd absolutely go for a 240 and 2 slow fans again - if it doesn't cool enough, worst case scenario: turn up the fans.This seems totally pointless to me. You don't need any review based on this case to know how well (or bad) a 240 rad will cool X components. What you should know is that if you plan to run a silent build (1150rpm fans at 7V seems like 600rpm to me), watercooling the gpu and cpu at 600rpm is simply IMPOSSIBLE if you plan to put any stress on your system... unless you are talking about low-end components. It will never work (and I'm not even talking about overclock).
I have both (aftermarket top and 670) as it happens, so it should work out nicely.
If you'd like to find me a review of a 3570K or similar with a GTX 670 running on a slim 240 rad with decent fans at around 600RPM, then please do. It's not like I don't know this, and it's not like I haven't looked, I wouldn't have asked if I knew the answer already.
I'm sure it would be a pain to assemble, fill, and bleed, but that's the price of an SFF case like this, and mounting a radiator externally is something that I would consider pointless, so to each their own.
