It probably fits lengthwise, but the pump at the end is pretty thick and will offset the rad relative to the mounting holes on the bracket, so it may not be possible to mount it.Hey guys,
I know the below has already been shown that the 295mm width will be a tight fit in the M1 for the EKWB Predator 240, but is there anyone willing to make up a mock-up cardboard version and see if it'd be possible? With 303mm available space, it *might* be able to be done? Maybe slipped in behind the case edges rather than on the radiator/fan mount?
There's only room for three 120mm fans, since the CPU cooler is tall enough that it blocks the rear half of the fan bracket.Do y'all see any problems with this build?
CPU Cooler: Noctua NH-D9L 46.4 CFM CPU Cooler
Case Fan: Noctua NF-S12B redux-700 33.5 CFM 120mm Fan (x4)
Depends which specific model. This one is fine, this one won't fit due to the PCB height.Video Card: MSI GeForce GTX 980 Ti 6GB Video Card
