NCASE M1: a crowdfunded Mini-ITX case (updates in first post)
Discussion in 'Small Form Factor Systems' started by wahaha360, Sep 15, 2012.
  1. Aibohphobia
    Aibohphobia [H]ard|Gawd
    1,340
    Nov 16, 2013
    I've used Shapeways, can be a bit pricey but the quality is good.
    I wouldn't recommend just taking my model as is and 3d printing it. It's really meant to be made from bent sheet metal.
  2. Synomenon
    Synomenon [H]ardness Supreme
    7,649
    Feb 10, 2007
    Ah bummer.
    I guess I'll have to stick with the SX600G then. I don't want my GTX980 being pushed or bent down at all.
    Was your custom bracket for the PSU mounted to the 2.5" drive mount on the front of the M1?
  3. Urelure
    Urelure Limp Gawd
    456
    May 15, 2014
    It was mounted the same way as the ATX PSU bracket that ships with the M1.
  4. Aibohphobia
    1,340
    Nov 16, 2013
    ^ This
    It's mounted using the same 4 screw holes the ATX bracket uses.
  5. cambrian
    cambrian Gawd
    607
    Aug 5, 2004
    any tried the h80i gt with this case? It has a 49mm thickness. The original h80i was 38mm and it fits.
  6. exelias0
    exelias0 Gawd
    703
    Sep 19, 2010
    Anyone have a set of black panels they don't want? (Any version, ODD or no ODD) I put a little scratch in mine and it made me sad :(
  7. Printermeow
    Printermeow n00b
    21
    Jun 16, 2014
    Will be building Titan X / M1 / PETG Hard Tubing build for my self
    [​IMG]
    [​IMG]
    [​IMG]
  8. EpicFruit
    EpicFruit n00b
    11
    Feb 24, 2015
    Does anyone know if the EVGA GTX 980 Hybrid will fit into an M1? My concern is with the side panel clearance, and whether there is enough room for the tubing that is running out from the side of the GPU.
  9. Diverge
    Diverge Gawd
    536
    Nov 22, 2005
    Heads up for anyone using a Swiftech H220 in their M1; seems those plastic elbow are pretty crappy:
    [​IMG]
    [​IMG]
    I went to swap out a GTX Titan for a GTX Titan X today, and that's what I found.
    The kicker is that Swiftech says the M1 is not the ideal case for the H220, and will deny your RMA, saying the failure is from user error. That too much stress was put on the elbow (even though there is plenty of hose slack, and everything fits pretty good).
    http://forums.swiftech.org/viewtopic.php?f=2&t=3102&p=13730
    The fact that they are calling this user error right away, and not even admitting the possibility of a defect leaves me with zero confidence in the H220, especially when it's right above a $1000 videocard. I just figured I'd give a heads up for others using the H220, because to me, those elbows seem like a weak link, and I'm not the only one who has had this problem. Here's another guy on their forums, which a leaking elbow, that they also blamed on user error: http://forums.swiftech.org/viewtopic.php?f=2&t=3094&sid=3c9a75024dc6cf5f43f503254a636b40
  10. ghostwich
    ghostwich [H]ard|Gawd
    1,723
    Sep 10, 2014
    There are other Swiftech stories in this thread...
    http://hardforum.com/showpost.php?p=1041006534&postcount=12585
  11. Necere
    Necere 2[H]4U
    2,729
    Jan 3, 2003
    Nobody has gotten the H80i in with both fans. The most I've seen is with one regular and one slim fan. Given that that configuration is about the same thickness as the H80i GT with one fan, it's conceivable that could fit. Nevertheless, I wouldn't recommend it, since it will be under-fanned and probably perform no better in that configuration than a thinner rad with single fan.
  12. antok86
    antok86 [H]ardness Supreme
    8,089
    Feb 26, 2006
    tempted to try to cram my current rig (bitfenix prodigy) into this case...
  13. antok86
    8,089
    Feb 26, 2006
    Will this case fit 2 x 2.5 drives, h100i, asus 970 strix and a sfx psx?
  14. Drewbies
    Drewbies n00b
    2
    Mar 24, 2015
    Yep. I have 2 x2.5 drive, a h100i and a 670 in mine with the sfx-L 500w powersupply. Its a little bit tight where the GFX meets the powersupply but you can squeeze it. IF you went with the standard SFX size more room opens up.
  15. antok86
    8,089
    Feb 26, 2006
    I thought i saw someone post that a 970 strix didnt fit. Would like to confirm with anyone that has tried
  16. Siba
    Siba Limp Gawd
    341
    Dec 28, 2012
  17. Phuncz
    Phuncz 2[H]4U
    2,630
    Apr 12, 2009
    LOL not this Swiftech Warranty Dodge Tactic again. Not so long ago they wouldn't honor warranty because someone was using an 450W SFX PSU with a high-end GPU (which many here can attest works flawlessly) because the Nvidia website says it would need a 600W PSU (if it was a crappy PSU).
    It's remarkable how crappy their support is, it might as well have said on the box that you should only use this inside a computer that's on their Qualified Vendor List.
    Someone give this guy a book on basic physics. It's getting sad.
  18. Necere
    Necere 2[H]4U
    2,729
    Jan 3, 2003
    It won't fit. The problem is this corner of the PCB, which runs into the rear chassis flange:
    [​IMG]
    If you're not afraid to take a dremel to a $350 video card (and void your warranty), it's a fairly minor mod to make it fit.
  19. Necere
    Necere 2[H]4U
    2,729
    Jan 3, 2003
    It's a shame how problematic the H220 turned out to be; in theory it's an ideal all-in-one watercooling kit for the M1. But between the (apparently) flawed pump design, Swiftech's questionable support practices, and Asetek's patent monopoly, I guess it wasn't meant to be. The latter is especially troubling, since it means it's unlikely we'll see any companies do an expandable AIO, unless Asetek themselves are involved. I was looking forward to the Fractal Design Kelvin series, but it looks like they won't be available outside of Europe.
  20. Anagog
    Anagog n00b
    50
    Dec 13, 2014
    Correct.
    Incorrect.
    If you take out the rubber plug for the clip at the back that bit fits in fine. The problem lies with the heatpipe. It sticks out over the edge of the case and prevents the side panel being put on. Same problem with the 980 Strix.
    EDIT: Upon closer inspection it seems that the 970 strix is very marginally shorter which may allow the side panel to close.
  21. Necere
    Necere 2[H]4U
    2,729
    Jan 3, 2003
    Yeah, I would've thought the person that did that mod would mention the heatpipe not fitting. So the 980 Strix is out, 970 Strix probably fits with some modding.
  22. ghostwich
    1,723
    Sep 10, 2014
    That said... my personal experience with an Apogee Drive ii has been positive. I also appreciate Swiftech's Lok-Seal compression fittings being compatible with 17mm wrenches.
  23. exelias0
    exelias0 Gawd
    703
    Sep 19, 2010
    Now you guys have me worried. Maybe I shouldn't be using an H100i. It really took a lot of force to get the thing in there, with those stiff hoses.
  24. fenrisx
    fenrisx n00b
    11
    Mar 15, 2008
    Can't wait!
    March 26, 2015 , 8:59 am
    Processed Through Sort Facility
    TAIPEI INT AMF, TAIWAN
    Currently "Inbound Into Customs"
    Moving my stuff out of a Fractal Node 605 w/ an ASUS RoG Maximus VI Formula board into the v3 of this case w/ an ASUS RoG VII Impact board. I still need to get a smaller PSU -- but I'm waiting until this thing is closer to delivery.
  25. Phuncz
    Phuncz 2[H]4U
    2,630
    Apr 12, 2009
    After a DOA Swiftech H220 and a EK Full Cover Water Block leaking (after one year), I've decided to stop with watercooling. I choose to go with about the largest air-coolers I could get for my build (Scythe Kabuto 2 and Arctic Xtreme) and it's made my system very quiet and less prone to problems like leaks and evaporation.
  26. antok86
    8,089
    Feb 26, 2006
    anyone got an extra one laying around they want to sell.
  27. Vittra
    Vittra Gawd
    894
    Jul 9, 2005
    Are you guys sure about this? Specs on cards show the 980 not being as "tall" or "wide" as the 970. 5.5 vs 5.3.
    980
    970
    This appears verified by DfknG:
    http://hardforum.com/showpost.php?p=1041288789&postcount=14785
    http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/68871-ncase-m1-build-minivalidus.html
    Unfortunately he hasn't posted an update on his build as of yet.
  28. Necere
    Necere 2[H]4U
    2,729
    Jan 3, 2003
    Hm, yeah... in the comments on his most recent youtube video someone asks him that very question and he does say the Strix 980 should fit better than the 970, but it doesn't look like he's completely sorted it out yet. Going by the specs though, you're right - the 980 seems like a more likely fit, though the PCB of both models looks like it will have the same problem at the back corner.
  29. antok86
    8,089
    Feb 26, 2006
    damn so tempted to get this case..but the part where the strix 970 doesnt fit. im willing to shave down part of the pcb if it fits.
  30. Necere
    Necere 2[H]4U
    2,729
    Jan 3, 2003
    The guy that did the mod to make the Strix 970 fit did say he was able to get the side panel on fine.
  31. Telecaster
    Telecaster n00b
    34
    Feb 6, 2015
    Good luck with that Liquid Ultra, no matter how many times I applied it (exactly as per their video and exactly how they described it) it didn't work for me, temps just kept going crazy under load. I gave up and went back to IC Diamond and the typical 'line across the die' method saw temps drop 20 degrees under load compared to the liquid ultra.
    Looking at my CPU cooler face it could well have been that it wasn't a mirror finish, but still, I expected better from all the hype.
  32. Anagog
    Anagog n00b
    50
    Dec 13, 2014
    Yes im sure...
    [​IMG]
    The 980 measurements don't include the heatpipe for some retarded reason.
    EDIT: Couple extra pictures.
    [​IMG]
    [​IMG]
  33. fenrisx
    fenrisx n00b
    11
    Mar 15, 2008
    ^^ That was yesterday.. had been that status for roughly a week. Today.. OUT FOR DELIVERY. I didn't expect that at all! Yay.
    I guess I should have ordered the PSU already! Luckily for a mere $9 for 1-day Saturday shipping I'll have it tomorrow.
  34. antok86
    8,089
    Feb 26, 2006
    ^^^^ is that 970 or 980
  35. Anagog
    Anagog n00b
    50
    Dec 13, 2014
    Thats a 980
  36. theGryphon
    theGryphon [H]ard|Gawd
    1,295
    Nov 21, 2011
    I have a question for M1 owners and/or Necere:
    How much does the AC cord stick out from the surface of the PSU, precisely, in millimeters?
    Thanks!
  37. Aibohphobia
    1,340
    Nov 16, 2013
    About 17mm from the metal housing on mine but there may be some variance due to differences in the AC inlet socket on different PSUs.
  38. Talon720
    Talon720 n00b
    15
    Dec 27, 2014
    I'm pretty sure I posted awhile back about the arctic mono plus on a 750ti not being able to fit. Well it fit but the side panel couldn't go on. So after buying a Raijintek Morpheus and finding out it didn't fit, but had some lower profile heatsinks I could use on the memory and vrm. I went back to the arctic mono plus and turned it so the heat pipes faced the rear, they almost touch the PCI slots. It fits great this way and I took the fan off and have a 92mm noctura redux 1600rpm fan connected to the 2-pin gpu stays pretty quiet. I tried a scythe slipstream to, but it seemed a little louder. Also the heatsink was cooking the back of the slipstream to the point where I couldn't touch it, remember the two aren't actully touching one another. Also the sleeve bearing seemed to develop a noise after that, coincidence? maybe..but the noctura works for now. I wouldn't mind using the slim 92mm noctura fan but it's PWM only, I don't think that will work well with a 2-pin gpu I assume voltage controlled connection. Just thought I'd give anyone a heads up on a different option as in sure this position would work on other cards.
  39. theGryphon
    1,295
    Nov 21, 2011
    Thanks bro!
    Is that on the SFX(-L) PSU? Can you measure on other units maybe too, preferably ATX?
    I appreciate it! :)
  40. Anagog
    Anagog n00b
    50
    Dec 13, 2014
    I measure my SX500LG at 18mm but this is with a tape measure rather than a calliper so it may be less accurate.
