goodbyegalaxy
- Jan 7, 2015
Did yours come with the V3 bracket? There are comparison pics a couple pages back.
I just got all the parts to start building my in my V3, but it seems that the SX500-LG is too large to accommodate my reference 970. This doesn't make much sense as I've seen others who have been able to do this without issue.
I tried pulling the wires taut and away from the GPU, but it seems like it's not going to work. Are there any recommendations for bending them? Does it basically need to look like a 90 degree bend?
That's a v3. You can tell because it has a cutout in the flange for the power cord.
Necere answered that a few post agoHi folks. I bought an M1 case one week ago (with the two week shipping option). I'm a big fan of this case, and respect all the work that's gone into it's design. I'm looking forward to using it.
So, sorry if this question has been asked a million times, but: It's been a week, and besides the initial recipt email from NCase, I haven't received any information. NCase's site lists the average time to ship at 1-3 days.
I respect that NCase is mainly two guys, and I'm not complaining about the wait. I just want to make sure there's not some well issue out there that I should know about- some reason that things wouldn't be going smoothly for a recent order.
Cheers!
-Orion
It's the Chinese New Year right now, so everyone's on break over there. The next shipment should go out at the end of the month or early next.
make sure only the 24 pin cable is bent from the front. the rest (8pin, sata, molex) need to be bent the other wayNot sure. I'd assume so? Here's a picture.
http://i.imgur.com/4Mr40xi.jpg
EDIT: After reading the comments Necere made, it looks like it's the right bracket. Maybe I'm being too timid about the bending of the cables.
Which of these pump tops for a DDC pump do you guys think would be better?
http://www.aquatuning.us/water-cool...r-ddc-cover-for-laing-and-swiftech-pumps-g1/4
http://www.aquatuning.us/water-cool...312/laing-ddc-top-silver-nickel-edition-brass
One thing to keep in mind is if you're planning to use a long GPU (w/full cover block), the pump+top will need to fit under it, and I believe only the Aquacover is short enough for that. If you're using a reference 970 w/short PCB or the like, either should be fine.Which of these pump tops for a DDC pump do you guys think would be better?
Great build. I like a well executed, more modest build just as much as the high end builds, which this is a prime example of.Not an uber build as I don't have the disposable income to throw at it, I've just migrated over my current system. Will probably upgrade over the coming 12 months but TBH this still does most of what I need.
The bits waiting to go in bit of a black and white theme going on:
99% buttoned up and done:
MSI Z77IA-E53
2500k @ 4.5ghz
Cryorig C1 with Thermalright TY-147 (amazing fan BTW)
Team Group 1600mhz RAM 8GB
Samsung 840 Evo 250GB
Palit Kalm X 750ti
Corsair CS550M (80+ gold, silent, can't praise it any higher, never heard it)
2x Corsair SP120 as case fans
Cable management wasn't too bad, but then I don't have any PCIe power to run so just a single modular SATA power.
Does anyone have any tips on cooling a msata on the back of the motherboard? Mines running a bit hot
How much space there is between ssd and ncase side panel?
Could you put thermal pad between side panel and ssd, so side panel would act as heatsink?
Hmm that could work but that would be a thick thermal pad needed
Does it align with the holes in the side panel? If so a thermal pad would compromise the passive air flow the msata drive is getting, for the sake of using that entire panel as a passive heatsink.
How hot is it getting? Is there something on the other side of the motherboard PCB that is contributing to heat in that localized area?
Also, does anyone know what combination of Bitspower fittings are used in this image to connect the GPU and CPU blocks?
This build is using a Aquacover DDC (dual version) under an EK block on a Titan Z, which will give you an idea of how it fits.I'm using a 980 with EK water block. So I'll absolutely have to use the Aquacomputer block, and it will absolutely fit?
presumably there is a very short piece of 10/12mm hard tubing between the two fittings at the CPU side.
That doesn't seem right, are you sure? Look at the fitting ends that connect the two fittings on the CPU side. That middle fitting doesn't look like the same connector on both sides. The side that connects to the CPU fitting looks twice as long.
Hmm, you've got a point there
Looking at Bitspower's own site instead of PPCs, I could see more easily all 220+ models of fitting. I found G1/4" Matt Black Dual Rotary Angle IG1/4" Extender BP-MB90R2LD and Matt Black Enhance Rotary G1/4" 90-Degree Multi-Link Adapter BP-MBE90RML.
Those could combine directly. What do you think?
Also, do you know what fitting is on the left side of the CPU block in this image?
https://i.imgur.com/v74WI8bl.jpg
It kinda looks like this one: a combination of BP-BS90R2LCPF-CC2 and BP-BSWP-C41J
Can someone confirm how Noctua NH-C12P SE14 fits with Asus Maximuss VII Impact and Ncase m1 v3?
"Yes, with heatpipes towards rear.
Works with removable cage (vs Noctua C14) but requires attaching the 140mm fan to the removable cage rather than to the heatsink itself (in the case of rear facing heatpipes) because the hard drive portion of the cage was in the way.
140mm fan attaches fine to the 120mm removable cage"
