Anyone have any tips on managing these cables a little better? I'm wanting to get a 92mm fan to go under the gpu fan and didn't know if there was any better way to tuck away everything other than under the gpu. Really wish i had the tools to make custom length cables
Please do!
ncase also informed that my shipment was about to be shipped 4th of february and they would email tracking to me code and update it also to paypal. That didnt happen so I guess there are delays. I have asked them for updated shipping info but havent revieved an aswer yet.
I am going also for m.2 pci express ssd. Note that there are several types of those disks and another are working in pci-e mode and other in sata. My choise was samsung xp941 256gb as new model xp951 seems to be impossible to get at this time. Note that this solution also shares pci-e lanes with your display adapter, so gpu gets 8x pci-e 3.0 lanes. Still it gives so huge boost for disk performance and maybe 1-2% drop for my gtx780 so I choose this over normal sata3 ssd. I will be usings asus maximus vii impact.
Is it a build with a V3 PSU bracket?To me it looks like it bends more in the picture than it actually does.
The GPU is a reference 980.
http://i.imgur.com/5t5OcpSl.jpg
Most of the excess PSU cable in mine is folded up and stuffed between the back of the PSU and my side HDD rack (would be against the Silverstone logo in your picture).
I'm using the shorter flat cables from Silverstone's PP05-E set and just the main 24-pin cable from the stock SX600-G set (since it's the only one that's shorter). You'll save quite a bit of space doing that versus using just the stock set. Well worth the $30 imo..
http://hardforum.com/showpost.php?p=1041115907&postcount=932
wow. i thought the 600w came with the shorter ones but i guess not. im really tempted to get them but im still wanting a few upgrades that $30 could go towards. ill definitely keep these in mind though thanks!
It's only a couple of inches shorter here and there.
So the short cable doesn't come as standard with the 600w PSU then? I thought I read that it did..
Still waiting for the SX500-LG but here's a pic of the bracket itself:
Also a poll: http://strawpoll.me/3598988
It looks like the SX500-LG just barely fits with the v3 bracket so I'm wondering if there's still enough demand to develop my custom design beyond a prototype.
Since I had several components lying around, I thought I'll take some more pictures with the Silverstone SFX-L. As Anagog already said, it fits quite well, I am surprised how well, because the Chieftec SFX-500GD-C hardly fit with a GPU without backplate (removing the sleeve from the Chieftec cables should help though).
NCase V3
Silverstone SFX-L
MSI GTX 760 Twin Frozr w/o backplate || OCUk GTX 970 w/ backplate
http://imgur.com/a/El2Ss
If you deiced not to produce them, will you share the files? (I'll get someone local to make me one)
If a production run isn't feasible I could make the files available.
Whats the min.quantity for it too be viable?
I'd love two of those psu brackets for my V1 and V2. It would be awesome if Lian Li ended up making them for future versions. I'm kinda obsessive but I like it when it's the 100% same color and material as the rest of the case
At least it's black. That's probably the easiest color to get close for a match and I doubt anyone would notice but ourselves.Not sure yet, I'm waiting to test it out to see if there are any changes needed. Then I'll start emailing manufacturers and getting quotes.
Yeah, I probably won't be able to match the paint exactly. For a small run like this we'll just be at the mercy of whatever the shop has in stock.
Fans better on a 240 RAD on panel side pulling in or on inner side of rad pulling in/out?
so the question is whether my ram is low enough. anyone know?Yes, with heatpipes towards rear. Can't use bottom 140mm fan on the bottom. Can't use hard drive cage. A 120mm fan can be installed under the NH-C14 if low profile RAM is used.
Got a SFX-LG today and jammed it into v1 with a reference 780...pretty nasty process to say the least but somehow it all fit. Cannot recommend though.
