NCASE M1: a crowdfunded Mini-ITX case (updates in first post)
Discussion in 'Small Form Factor Systems' started by wahaha360, Sep 15, 2012.
  1. Curiositie
    Curiositie Limp Gawd
    465
    Jun 4, 2014
    It's a 750ti, so it doesn't put out much heat.
    It idles at around 30-35C, and after playing AC4 for about an hour it gets to 70C.
    I ran the burn in benchmark on furmark before replying to this, and it started at 35C, got to 86C, and got back down to 44C in 15 Minutes.
    [​IMG]
    I'll measure in a minute, but I think there's only room for slim fans, though I think they would be sufficient for newer cards like the 970.
    Edit:
    From my measurement 15mm fans would be easy to fit, 20mm would fit with some shoving, and 25mm almost definitely won't fit.
    From my rough measurements I think, at least in my case I could fit a Prolimatech vortex 14 between the GPU and heatsink.
    I could definitely fit a Scythe Kaze Jyu Slim or prolimatech Vortex 12 or slim silverstone 120mm.
    Though I'm pretty sure only the Prolimatech fans are PWM, so...
  2. Qrash
    Qrash Gawd
    973
    Oct 9, 2014
    Thanks for measuring. One last question: there seems to be a bit of space between the heatsink and the graphics card. Could slim fans fit there as well (for push/pull) or instead of underneath?
  3. Curiositie
    465
    Jun 4, 2014
    I believe so, the heatsink has 19mm between the underside of the heatsinks and the lowest point of contact, so any 15mm fan should fit so long as there's nothing sticking up too far from the PCB.
    In my situation, I might actually be able to put the 140x15mm prolimatech fan there, but I wont know for sure unless I try. (Though the Scythe Kaze Jyu would look better being 100mm wide)
    Cropped version of their dimensions PDF (Click for big)
    [​IMG]
  4. JaccoW
    JaccoW [H]Lite
    100
    Jun 1, 2014
    Very nice setup. I think I will be doing some reading up in the next couple of months to finally start building my Ncase.
    Which PSU is that though? I have my eye on the Corsair AX760i but at 180mm x 150mm x 86mm I am not entirely sure. It looks big.
    Combine it with the newer extra short GTX 970's this should fit just fine.
  5. Curiositie
    465
    Jun 4, 2014
    It's a Seaonic X-Series 650w from 2011 (the newer version has a switch to choose between always on or adaptive fan speed).
    It's 160mm long, and there's about 15mm between the cooler and PSU.
    That's my plan, though I was thinking the Gigabyte or Zotac. :)
    Edit:
    I tested a 750ti that hhad a pcb the same length as the Zotac, and it fit fine, though it was near the limit of fitting.
  6. Kasul
    Kasul n00b
    10
    Jan 21, 2015
    Does anyone know how long the custom inspection process usually take? It has been stuck for over week at L.A.. I've search the forum and couldn't find the answer. I have all the part except the case to start building.
    Edit* Nvm, It has just arrived at delivery office, can't wait!
  7. thefivetheory
    thefivetheory [H]Lite
    74
    Jul 29, 2013
    Here's a stupid question: would two SFX PSUs fit in the M1, side-by-side, with any room to spare for the side bracket? For the purposes of the question, ignore how you would mount them, if you would be so kind.
  8. Aibohphobia
    Aibohphobia [H]ard|Gawd
    1,340
    Nov 16, 2013
    I don't see why not, ATX fits with the side bracket and that's 150mm wide while two SFX units back to back would only be 127mm
  9. thefivetheory
    74
    Jul 29, 2013
    Hmm. Thanks!
  10. Qrash
    Qrash Gawd
    973
    Oct 9, 2014
    So clever! Should work fine so long as both PS fans are exposed.
  11. NA STI
    NA STI n00b
    17
    Dec 22, 2014
    Sorry if I missed this but has anyone actually test fit a 500w sfx-L PSU WITH the v3 bracket yet with a full size card?
    I Just saw the amazon price on this PSU and its only 96$, which is a much better deal then the 100$ 450w sfx psu + 25$ fan swap + $30 slim cable upgrade
  12. Qrash
    Qrash Gawd
    973
    Oct 9, 2014
    Out of stock. That was quick.
  13. jb1
    jb1 Limp Gawd
    495
    Dec 27, 2014
    Not sure if it was actually ever in stock... I think I saw the product page go up.
  14. Qrash
    Qrash Gawd
    973
    Oct 9, 2014
  15. thefivetheory
    74
    Jul 29, 2013
    Seems like one of the trickier issues would be the PSU cables. I would imagine a Y-cable version of the one the M1 comes with should exist, but I don't have any idea where to find one.
    I'm really trying to find a semi-reasonable way to stick a 295X2 in my M1 but it's not easy.
  16. Curiositie
    465
    Jun 4, 2014
    You could probably just buy a second internal adapter thing from the website and do it that way.
    And if you don't want two power cables coming from the case,use a y cable at the back.
  17. iFreilicht
    iFreilicht [H]ard|Gawd
    1,348
    Sep 23, 2014
    I have no idea what you're planning to do, but I really want to know!
    EDIT: Oh, you want a 295x2 in there. good luck!
    You may want to look at PCIex16 risers like Tschus has used, so you can move the GPU down by one slot, which should leave enough room for the PSU cables.
    Oh and the outlet you'll probably have to solder yourself.
  18. JaccoW
    JaccoW [H]Lite
    100
    Jun 1, 2014
    Thanks for the answer. :)
    So the Corsair PSU would at least fit although the cables will be at a tight angle and an aftermarket cooler would be out of the question.
    We already figured out a while ago that most GTX 970 models have a very short PCB. The Zotac one you have there looks like it might fit without the shroud.
    And the newer Seasonic also comes in a Platinum version in that smaller size. Excellent. :cool:
  19. Curiositie
    465
    Jun 4, 2014
    I've got my eye on the fanless 460W. ;)
  20. Aibohphobia
    1,340
    Nov 16, 2013
    Ok, here's what I've come up with for the SFX-L bracket so far:
    [​IMG]
    So with the PSU in the forward set of holes the connectors should clear 10.5" cards like the reference GTX 980.
    But if you have a shorter video card you can use the rear set of mounting holes so the 2.5" mounts on the inside of the frame are useable.
    Thoughts?
  21. Curiositie
    465
    Jun 4, 2014
    The GTX 960 looks kinda eh. :(
    I guess I'm waiting for 20nm, or just going to do a 970 once taxes happen.
  22. Siba
    Siba Limp Gawd
    341
    Dec 28, 2012
    Whatever happened to the M1 builds thread? I guess I'll just add mine here for now, can't find the old thread. I was too impatient to take pics during the process
    full potatocam album
    http://imgur.com/a/nOWat
    [​IMG]
    [​IMG]
    [​IMG]
  23. flod
    flod Gawd
    935
    Jul 10, 2014
    nice! how are the temps and the noise? I'm planning to run pretty much the identical wc loop as you've got. how would you rate the relative loudness of the psu, the pump, and the fans?
  24. Necere
    Necere 2[H]4U
    2,733
    Jan 3, 2003
    What about a 140mm long non-modular ATX power supply? Modding the cables on that seems like a simpler solution than trying to shoehorn and wire up two SFX PSUs in the case.
  25. Blk
    Blk Limp Gawd
    153
    Jan 17, 2015
    When can I have one? :D
    Don't know if it would be possible but, what if you'd move it towards the "mobo tray side" as much as possible to give clearance for a (slim) fan or drive on the side bracket?
    Does it need a "lip" at the back to give it strength? (and a notch in the right place for the cable)
  26. Urelure
    Urelure Limp Gawd
    456
    May 15, 2014
    If you decide to make this, do you have any idea of what your asking price would be.
    I am way more interested in this than a V3 bracket for future compatability. I'd easily buy one off you if the price isn't insane. Are you thinking steel or aluminium? Not that it matters too much...
  27. EdZ
    EdZ Gawd
    773
    Jan 28, 2008
    But then you couldn't pack 1200W of power into a 12.6L case, for bragging rights (nearly 100W/L!).
  28. ghostwich
    ghostwich [H]ard|Gawd
    1,723
    Sep 10, 2014
    http://hardforum.com/showthread.php?t=1820531
    It's labeled "v2" but honestly there should just be a general build thread (since version differences are fairly minor).
  29. Aibohphobia
    1,340
    Nov 16, 2013
    I originally planned to put it toward that panel as much as possible but I had to shift it inwards so all the screws were accessible due to the flange on top the frame.
    The PSU itself will stiffen the bracket, I prefer that because I could place a notch for the SX500-LG but what if future models have the AC inlet in a different position?
    No idea on price yet, I'm going to get a prototype for myself and if it works out like I think it will I'll look into a small production run.
    It would be powder coated 20 gauge steel with threaded inserts like the parts on Nova.
  30. Urelure
    Urelure Limp Gawd
    456
    May 15, 2014
    Great. I'll keep an eye out. Thanks
  31. Phuncz
    Phuncz 2[H]4U
    2,630
    Apr 12, 2009
    I have the v3 bracket (for my v1 case) and also a new extension cable, but I'm waiting for availability of the PSU in Western Europe. As soon as I have it, I'll test it in my setup and make pictures without the use of potatoes.
  32. Synomenon
    Synomenon [H]ardness Supreme
    7,649
    Feb 10, 2007
    If you can get this bracket made just right, I'm in for two!
  33. superjec
    superjec n00b
    10
    Jan 16, 2015
    Any ideas how to remove light scratches on Silver M1?
  34. Siba
    Siba Limp Gawd
    341
    Dec 28, 2012
    All temps dependent on ambient environment temp
    CPU idle 30-35c
    GPU idle 32-34c
    CPU heaven benchmark load 60-69c
    GPU heaven benchmark load 45-49c
    CPU firestrike benchmark load 60-64c
    GPU firestrike benchmark load 44-47c
    It may not be perfectly game stable, I may have gotten a dud 4770k. Seems to be exponentially more unstable if I let the cpu hit 70c
    As far as noise profile, I'd say Pump > GT AP14 > psu
    The PSU has the bird singing/whistle when the fan starts up, but its not really that big of a deal
    The pump was super loud until I used asus ai suite 3 to get the PWM below 40%. Right now I think my curve goes from 28-36 or 38% max
    The fans are on a sunbeam 2 channel fan controller that's mounted in the third pci expansion slot, below the GPU. Seems to work well enough, but being analog I can't give you any measurements. I just leave the case fans at 100% from ai suite and turn the knob on the sunbeam controller to my liking
    Overall the noise isn't as quiet as a super quiet air system, but I think I'm satisfied. In no way could I hear the system over any type of music that I'd be playing. The noise is more consistently quiet than when the GPU was air-cooled. Definite improvement, as all you can really hear is air flowing through and slight pump noise if you listen pretty closely. The main advantage is there almost no difference between idle/browsing/video playback and full on gaming/benchmarking.
    Maybe one day I'll clean it up enough to post to /r/battlestations :)
    Thank you, put my build in there
  35. Kasul
    Kasul n00b
    10
    Jan 21, 2015
    So I recently build m1 v3 with Asus strix 970 and you guy were right that the PCB is too wide, but since I cannot get a refund I made lemonade, and cut a bit off.
    The Coolermaster Glacer 240l has a pump that is too wide where the tubes are coming out on each side due to the daughter board and the ram for my motherboard asus vii impact so I'm currently using stock one. If only the pump have both tube coming out from just one side, then this would fixed my problem.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  36. Aibohphobia
    1,340
    Nov 16, 2013
    Can't argue with results :D
    Doesn't the heatpipe interfere with the side panel though?
  37. Kasul
    Kasul n00b
    10
    Jan 21, 2015
    I can put the panel back in just fine, although I think it might be touching it which I don't really mind. I think it align perfectly with the dual fans and outer frames. If I look from top down position, I can barely see it.
  38. thefivetheory
    74
    Jul 29, 2013
    Yeah, that probably makes more sense honestly. I just happen to already have an SX600-G and an ST45SF-G (I wish the naming convention was the same for those two as I can never remember the 450w's model #) on hand already. I guess a Seasonic S12G-750 would probably do the trick... pretty sure that's the highest wattage 140 mm PSU around.
  39. flod
    flod Gawd
    935
    Jul 10, 2014
    is the pump still more noticeable than the psu at load?
  40. Mackan
    Mackan Limp Gawd
    379
    Jun 8, 2014
    My trouble with the V3 bracket was resolved. The customs fee was removed. Lian Li had done everything right, set the correct value on the package, and instead there was some kind of mix up later on.
