Half Life
- Apr 26, 2014
Guys i can't decide, H60 or cryorig c1? i'll buy a noctua industrial fan, the NF-F12 2000rpm if i buy the H60 or NF-A14 2000 IP67 PWM if i buy the cryorig. Which do you recommend?
I received a mail 5 hours ago:Anyone received their V3 PSU bracket yet? Ordered 13th, supposed to ship 18th via USPS. Have not got any tracking information via email or in Paypal.
We are preparing to ship your M1 Accessories on Jan 5, 2014 (Version 3 SFX Power Supply Bracket and Version 3 Panel Kits have already shipped, we will send the tracking numbers when we get them).
Is that necessary for using the SFX-L? Because I plan to get one as soon as I can find it.I also ordered a power cable which explains the extra week I guess.
Also, as a suggestion for a v4 revision.. figure a way to have Lian-Li weld in steel inserts for everything requiring a damn screw![]()
I also ordered a power cable which explains the extra week I guess. It doesn't matter, the SX500-LG isn't available yet anyway.
I got a gigabyte 970 itx. Just fyi for anyone considering this card - it is super loud at idle even after setting the fan to a minimum speed of 33%. It is not a good option if you are looking for a quiet system.
Your best bet is probably 6/32. It's just a bit bigger than M3.
The side bracket mounting points got inserts but not the expansion brackets.
Instead of retapping, I recommend you use a bolt and nut with plastic washers to get it really tight.
Unless Silverstone makes a turn around with their 600w SFX unit in the next few months I'll probably be grabbing the 500w SFX-L.
Have a V3 on order and wondering if a pci-e riser such as this one would be able to drop the card one slot without any physical interference issues. Card would be a water cooled GTX 980.
Edit: One more question, is there a NCASE 3D model available to public for part fitment testing? If not, how much space is there between bottom of rear 92mm vent and power port?
While supplies last, which will probably be through February.How long would it be possible to order the V3?
The case supports slim 120 or 240mm AIOs out of the box - no modification necessary.can this be modified for AIO coolers to be used?
It was designed for 12.7mm optical drives, so there's no issue.Any issues with the 12.5 mm width models, versus the 9.5 mm models??
Congratulations Necere!
and wahaha360!
The guy who started all the 'Aluminum SG05 evolution' madness.![]()
I'm waiting for AMD to release some more bridgeless GPU's for Crossfire, than I'll try making dual GPU's on mITX work.
