gameaholic
- Dec 15, 2010
FYI the V3 case comes with the revised SFX bracket, so you don't need to order it separately. It's just offered for those with the earlier versions that want the slightly better compatibility it offers for the new SFX-L PSUs.
No discrete GPU in your build?
Oops. Re-using 780 Ti
NH-L12 Should be good though right? Looking for the most quiet solution since this will be in a bedroom. I was gonna go with the H100i but I've heard it can be kinda loud. Is this still true if I replace the fans?
Just wondering why the 2x 500GB, instead of just getting the 1TB 840 or 850 Evo?
The 1TB is always cheaper than 2x 500GB and will allow room for an additional 2.5" drive upgrade later. I can see maybe wanting a pair for RAID, though I've seen a few places recommending that you just go with a single larger SSD instead..
http://www.tomshardware.com/reviews/ssd-raid-benchmark,3485-13.html
Actually, if you're going with the Impact VII, just get the faster XP941, and then add secondary SSD/HDD as needed..
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147349
Thanks! I forget, is there something special I have to do to boot from that?
