It's an interesting board. Probably mostly directed at Asia though. I spy a single HDMI, VGA and two PS/2 connectors for mouse and keyboard.A while back, some people were discussing mATX boards that fit the Ncase M1, basically because there are FlexATX boards (mITX but with 3 PCIe slots) and wrongly named mATX.
Gigabyte was so nice to grace us with a G1 Gaming series H81 chipset board:
An Intel NIC and a Realtek ALC892 sound chip with decent sound-caps apparently. Although the ALC1150 would have been prefered, this board might offer options for people seeking to add a TV tuner or a dedicated sound card.
Link: http://www.gigabyte.com/products/product-page.aspx?pid=5177#ov
It's still very basic with just two rear USB 3.0 ports (no 3.0 front header) and the bare minimum of ports.
If I fill my res (Ncase M1 res) to about over half of distilled water, the pump is pretty silent.
If I fill the res all the way to the top, the pump is so loud like a jet engine.
I dunno how to prime it actually haha
The loop is full and the res is full too, pwm header is connected
Going to get my liquid metal tomorrow and see how well my temps are
Ok, so I've swapped out the Corsair H75 for a SilverStone NT06-Pro.. I still have two fans on the side bracket, blowing towards the NT06-Pro. / motherboard and one fan on the bottom blowing up into the case. I also have a video card w/ blower style fan (GTX770), sucking air out of the case and exhausting out the back.
If I have the PSU fan facing inwards (sucking hot air out of the case and blowing it out), will I still have positive pressure in the case? I've removed the Demciflex filters because I found them too restrictive. Couldn't feel the fans blowing any air when I had the filters in.
Nice build... must take pics with the fans lit upSo I have three case fans (two on the side bracket and one on the bottom), all three sucking air into the case.
The one on the bottom just happened to align almost perfectly with the GTX770's fan and the side fan closest to the front also aligns pretty well with the SX600G's fan. The side fan closest to the rear of the case sits almost directly on top of the NT06-Pro..
The only exhaust fans are the video card's and the PSU's.
I'm using these fans:
Enermax T.B. Vegas UCTVS12P-W
Sure can.I'm 100% certain the answer to this is in the thread somewhere, but I am having no luck whatsoever finding it... is it possible to mount 4 HDDs on the side panel (assuming one had an extra mounting bracket)?
Not sure offhand. W360 will be able to tell you though, so you did the correct thing in sending an email.Aha. Thank you! I don't suppose you guys have extra HDD cages avaialble to order... I submitted an email via ncases.com in case.
Glad to help. A warning about liquid metal: I would only recommend it when the two metal surfaces are nickel. I've seen plenty of examples (e.g. delid thread on OCN) where copper plates absorb the gallium and becomes hard over time.
Of course it depends on the sum of the airflow, but surely 3 x 120mm fans will produce more airflow than the 80mm PSU fan.
How do you spread it? I'm getting worse thems with the metal than with grease
Pea size in the middle or a thin line across the die?
Um... Wasn't there a roadmap a few months ago detailing the future events of Ncase by Necere? I'm pretty sure it said that there was going to be extra Ncases leftover from production that were going on sale on Oct. 26.
Edit: To my disappointment, it turns out it's only silver, non-ODD V1 editions that are being sold.
Yes, a quick run through all the combinations:
Version 2:
Black: 14 with ODD slot, 8 without
Silver: 16 with ODD slot, 1 without
Version 1:
Black: 1 with ODD slot, 0 without
Silver: 1 with ODD slot, 3 without
check out this video http://www.youtube.com/watch?v=qFhbqiFh9Us
I wouldn't recommend a passive PSU in this case unless there is a fan somehow moving air in there. Heat can build up in this case without any airflow. But you could just look at the quietest 120mm fan PSU's, as long as you keep in regard what limitations this involves when using an ATX PSU inside the Ncase M1.
I too would agree with potential heat concerns due to potentially reduced airflow opportunity. I have had experience with a Seasonic M620 PSU and that silent enough for me to be happy to call practically silent. Its an old one, but seasonics are known for their smooth quiet low rpm fan. A passive PSU is one that relies on airflow from the rest of the case to help it stay cool. The NCase may not be one of the most ideal, but if you have sufficient supportive airflow from the rest of the case then it could be an option. If your adding a low RPM fan onto a passive PSU, you might as well go for one that has a fan within it (As Phuncz suggested). A high efficiency PSU with a semi-fanless design, or more importably, a quiet fan will be quiet enough in my opinion. Realistically the rest of your system would be a bigger concern. For example, your CPU fan must be just as quiet, and you are running a purely SSD only setup for a (properly quiet PSU fan) to be an annoyance.
I know there are PSUs out there with noisier fans, but historically seasonics have been good in my limited experience. More important is choosing a CPU fan with a low enough idle RPM, quiet bearings, and quiet motor. I have dozens of fans I've bought in search of a quiet fan, and after all this money, still haven't found the perfect fan. Some are better suited for specific applications.
e.g. My CPU uses a Scythe Glidestream because it has a very low starting RPM, perfect for CPU fan usage (about 300 rpm), but it ticks very mildly. This was acceptable as it spends half its time off, and the low starting RPM was the most important factor. The slipstream was a quieter option, but its power consumption was higher).
For the PSU, I went with a Scythe Kama 2, because its a quieter motor, but the higher starting voltage/rpm (about 550) was not as much a concern as this fan would not be required to start/stop regularly.
Case bottoms use the Scythe Gentle Typhoons as the give maximum static pressure, a strongly beneficial factor in that location with filters. Bearing noise is its weakness, however its location on the case bottom masks the noise concern.
What is the rest of your build like? I'm assuming your not going for an outright gaming machine, as you might be going with an iGPU? A decently large, low airflow CPU cooler? And SSDs all round? A motherboard that turns off the CPU fans when not needed?
Look forward to seeing your build come together.
FTFY. Modular plugs make the PSU too long, whereas non-modular has a single cable bundle that bypasses long GPUs.Thanks. I am aware of the limitations with an ATX PSU. Non-modular 140mm in order to use full length GPU.
It's actually pretty solid - particularly with the panels on. You have to apply some significant force to make it flex like in the video. However, it won't do particularly well if dropped when fully loaded on to hard surfaces or being crushed by errant forklifts. So try to avoid those kind of things and you'll be okay.Hello,
is the base frame not a bit wobbly? It has this slim stripes of aluminium and no braces? When I watch the following I have no trust in the base
http://www.youtube.com/watch?v=GPbBm1YC7Ts&feature=youtu.be
I do not want to talk the M1 down. I love the considered concept, the extreme nice and clean design and the cooling possibilities for this small case. I do want to order next time one.
But I wish the base frame would be made of sturdy steel. I think the weight ascept is pretty uninteresting.
I'm going to say... signs point to yes.Plans a for another batch soon?
Yes, though there are only a couple of things that need addressing over the V2 cases:Yey! Are there any revisions/changes you think you'll make over V2?
Were you the guy in... Mexico? I think we're considering some alternate payment options (maybe even including Bitcoin), so we'll see what we can do.When? But this time help me to pay, the last time i can't pay on the page with paypal i don't know why, remember?
It's 1.5mm throughout - the panels, chassis, and all included brackets.Thanks for the fast response. I do never drop my hardware ^^
How thick are the base frame aluminium? The panels are 1.5 mm thick, right?
Hi , guys. I want to show my friend worklog forum PcLab.pl
http://forum.pclab.pl/topic/994392-NCASE-M1-HEXXEH-FastMod2/
Hot damn that's a fine looking build! Love the custom-painted GPU!
