NCASE M1: a crowdfunded Mini-ITX case (updates in first post)
This won't fit the Ncase @ 63.5 mm... but wow: Aqua Computer Airplex modularity system 240 mm
EDIT: Apparently the newly revealed Airplex Radical 2 might be a better fit for our cases. @ L 280/284 x W 140 x H 40mm. Though we'll have to wait for the 240 models to be revealed.
What is the best possible way to securely mount ddc pump at the bottom front case? Now i have the pump free standing and that cause slight vibration and noise even with the weight from phobya top.
I believe some people have used a Shoggy Sandwich but they had to take out the foam part in between.
Perhaps a layer of Sorbothane with double sided tape?
I bought a thermal pad off ebay and used a cheap aluminum IC heatsink w/ a hole drilled through it to mount it to the bottom of the case:
Pump
Thermal Pad
Case floor
Aluminum heatsink
My pump is MCP35X so it has hole in the bottom already for the swiftech heatsink kit to cool it down
Will try to add pic later
Can anyone tell me the clearance between the bottom of a GTX card with full EK waterblock and bottom of the case?
Around 1.8" with my ek thermosphere, not sure if that helps any. Also not much clearance at all, mcp35x with alphacool is less than 5mm clearance
These pictures answer the previous question and maybe you can judge exactly how much space is available (hint: almost none)
Thermal pad doubles as the vibration dampening material..
Just measured it, 46-48mm clearance between the bottom of my ekwb gtx 670 waterblock and the bottom of the case.
Nice build. So the consensus is to have the PSU mounted so that it pulls air from inside the case? Also, do the grills that come with the case have a purpose or just for show? :)
Woops, no sorry.. I completely missed what direction I wanted to have the PSU in. Of course I want the fan to face the back of the case all alone.
Fixed that now! :D
Fixed that now! :D
Kosire, is there either an objective (temperature/performance) or subjective (noise) improvement/degradation when you orient the power supply that way? Just curious :)
There are potentially quite a few factors to take into consideration:
Fan pulling from outside the case -
+ Pulls cool outside air straight in
+ Minimal obstruction to airflow for PSU fan
+/- Fan noise directed from right side of case
- Relies on internal 80x15mm PSU fan to draw air
- Restricts airflow through second 120mm side inlet
Fan pulling from inside the case-
+ Can direct cool air to PSU with 120mm fan, potentially reducing PSU internal fan speed
+ Fan noise muffled by case internals
+/- Fan noise directed from left side of case
- If 240mm radiator installed, hot air will be fed to PSU
- If no ventilation fan installed, will pull warm air from case internals (heated by motherboard, potentially CPU HSF, potentially non-blower GPU HSF)
There are potentially quite a few factors to take into consideration...
Oh, absolutely - I ask because not many people have tried orienting it both ways. I'll take what information I can get ;)
The way I see it, though: if flipping it (so as to have the PSU pull air from the right side of the case) doesn't improve anything in that configuration -- or makes noise/temperature worse -- probably no-one with air-cooling should do it. Especially since that's a build with a fairly hot card with an open cooler, and the hungriest Intel CPU you can put in there.
If you have a radiator, that's different, but assuming the same CPU/GPU, it might not be that different. That would really need to be tried and tested, though. Intuition tells me you'd want to flip the power supply, but intuition can be wrong.
No difference yet.. except I can hear the PSU fan more since it's facing towards me now instead of facing the opposite direction and hiding inside the case.
But logicially it should be better.
I'm gonna try and rotate the CPU fan too, to see if there is any difference on CPU temps.
Will try with double sided tape.
That is not a pretty sight at the bottom. Is the heatsink really doing its job? How is the contact between the pump base and the heatsink?
I didn't have access to a machine shop, so that's basically what I could do with WD40 and a hand drill with a rotary tool to debur it a bit. You definitely can't see the heatsink unless you pick the whole case up so I'm not exactly hurting on the aesthetics side of things. Cheap and dirty solution I guess?
The heatsink comes into flush contact with the base of the case, and stays very close to the temp of the pump. Doesn't take much to stabilize the temps when I'm only running the pump at 40-60%. The base of the pump is also flush with the bottom of the case and can be adjusted because only one screw is used, and that location has tons of ventilation area to stick the screw through.
How feasible is doing something like this using the EK-SBAY DDC pump/res?
The right side would be for filling the unit, but once reseated would be far enough back when installed so that theres still access to USB/audio jacks.
I'm not sure what the inlet for the unit would be hooked up to though, because of limited vertical space under the GPU.
The right side would be for filling the unit, but would be far enough back when installed so that theres still access to USB/audio jacks.
I'm not sure but I am interested in an answer to this question.
Another minus is that you have to mount yet another dust filter. If the PSU pulls air from within the case then you only need dust filters on one side (+ bottom). But if it pulls air from the other side then you need dust filters on both sides.
I think I'll have mine pulling air from inside the case...I guess it will somewhat reduce the positive pressure but I guess not by much.
It would be nice if we could get some actual temps with different orientation of the PSU. Right now we're just speculating. ;)
Sorry lol. I'm not sure how to route tubing down to the bay so that it's also partially removable (like in the picture) for access to the fillports.
I've thought about it and don't see how you can remove the bay res if the GPU is installed. You'll have to ask Printermeow how he filled his.
This may seem like a dumb question but I have the EVGA slot load drive and can't physically press the eject button from the outside with all the panels on. Am I just supposed to use the operating system to eject every time?
Yes, you'll have to use the eject command in your OS. I have the EVGA slot load drive too in my Hadron. The drive doesn't even have a face plate and the M1 doesn't have an eject button on its panel.
Have you experienced this in games and if so, haven't your GPU temperatures increased because of this ?
Because I would suspect that the temperature difference is because of the warmer air that your GPU is leaving in your case.
No. GPU temps are the same. (35C idle, 60-70C load)
CPU temps both idle and load fell about 10C. From 45~ to 35~ and in games from 70-80~ to 50-60~ depending on the game (how much CPU they need).
The way the fan is now is also the "correct" way that Noctua suggets. I just had to try the other way :D
Currently I have mine setup practically that way, but without a GPU block, so instead of going to the gpu block, it goes between the gpu and radiator to the cpu inlet. With a 2 slot gpu cooler, the ek-sbay will not fit at all, but with a single slot waterblock, I believe it would. Now I don't know the answer of if the pump/res will be able to fit in AFTER the gpu is in place though.
https://imgur.com/a/cck52
So I got my W/C loop up & running for a few now
The pump, MCP35x is currently with the RMA dept as there was an issue that the pump would shut off if I plugged in the molex + 4pin pwm
I noticed that on my Apogee Drive II, the base has lots of black blotches and it doesn't come off with rubbing alcohol. Would it effect my temps?
Some shots
That's just tarnish (copper oxide). It won't affect temperatures at all.
Best way to make it all shiny again is Brasso, but diluted spirit vinegar will work as well.
Funny thing: traditionally in watercooling forums, people recommend ketchup and a toothbrush for cleaning copper blocks. A little unusual, but it does work as the ketchup contains the vinegar and the toothbrush is made of nylon so doesn't scratch :D
Hello there :) Just registered to ask pros a question. I'm selling my ps4 (cant stand 30fps) and planning to build a portable super computer with 970 gtx and i7 cpu. I'm planning to buy node 304 case first and when I'm able to get a hold of m1 I'll just swap cases therefore i'm looking for compatible parts.
1.From what I've read silverstone 450w psu will be no problem to handle the load of 970 gtx as well as cpu + 3.5inch HD and 2x 2.5 drives yes ?
2.Not sure about the cooling, i've watched so many videos and reviews and i'm torn between corsair h60 / h90 (dunno if they will fit in m1) and big nocua heatsink coolers. PC being quiet is most important to me and from what i've read 970 runs cooler overall so CPU cooling is where i'm stuck. Which ones do you prefer and would you recommend ?
Best regards :)
Welcome bydus!
450W will be plenty of power but you may consider the 600W or the upcoming 500W SFX-L. The 500W is not 100% confirmed if it'll fit in the M1 but it has a 120mm fan and Tony from Silverstone has said they fine-tuning it to be quieter than the 600W which is already quieter than the 450W.
For CPU cooling I'd go with the Noctua if you want a really quiet build. Depending on the ambient noise level where you live it may not matter but the pump will be louder than the fan at idle.
On the other hand, a closed-loop cooler is a lot easier to mount in a confined space, and has the advantage that the mass of the cooler is supported by the chassis rather than the motherboard PCB. If you intend to take your case on the go, this may be a valid consideration.
Sorry if im a bit off-topic with a video card question.
Been waiting for the Maxwell cards for my M1 and thought a 970 would do but im not so sure on the blower types offered, hence im leaning towards a 980 reference card.
Are all reference design 980 made by nVidia so that the only thing that differs is basicly the box it comes in or does the companies like EVGA, MSI, Palit, Gainward make their own cards and perhaps follow the reference specification but use parts of different quality?
So basicly what I wonder is, does it matter if I buy a Asus or get a cheaper EVGA GTX980 when both are reference models?
The two biggest differences between reference cards across manufacturers:
  1. Who assembled it.
  2. What warranty you get with it.
A reference card is just a card that has to conform to very specific and strict specifications, as set by the company that makes the actual GPU (in this case, nVidia). But even though the cards are all the same on paper, in reality they are manufactured by different companies that probably do things slightly differently. Maybe (if allowed) they use slightly different parts, but most of the time they just make them as they make any other video card, and ship it at or near MSRP, as it appears to the end consumer. So in terms of what you are physically getting, there's no meaningful difference, especially since the heatsink is totally identical.
So all you are really left with in terms of differences are the reliability of the vendor (how good is their manufacturing?), and what warranty they provide. Which is to say, I would get the cheapest one available that isn't from a questionable vendor.
Guys I have a problem! I did not think of this at the time but my plans may be messed up and I may have to go with a 2.5 inch ssd. Can you boot from a Samsung xp941 m2 ssd in an asus maximus VII Z97 board. I had my layout perfectly but if I can't boot from the m2 drive I will have to remove slim ODD and use 2.5" SSD there and external ODD and I'd rather not. Anyone have any experience with this?
Some shots
Incase anyone wondered why some cooling devices use nickel plated copper, this is the reason why
Yes, it was discussed recently in the M7I thread.
Many thanks for replies. I've decided to go for normal heatsink cooling solution, after much research i've decided to go for noctua nh-l12 or noctua nh-l9i. However i'm not sure if nh-l9i will able to be quiet and cool i7-4970 cpu - any comments on that ? Also pardon for being a noob but I wanted to know how the nh-l12 cooling works. I've seen reviews and temps but not sure how its able to cool down as its pushing air through the radiator and on top of the heatsink where cpu is. I know there is a second fan in there that does pulling on cpu as well, so how is it able to cool so well? From my understanding it would be best to do it in reverse (in m1 case) as it would get the hot air outside of the case and not warming up the motherboard. I pictured it on the attached picture. Can some1 explain it to me like im 5 ? :)
Many thanks for replies. I've decided to go for normal heatsink cooling solution, after much research i've decided to go for noctua nh-l12 or noctua nh-l9i. However i'm not sure if nh-l9i will able to be quiet and cool i7-4970 cpu - any comments on that ? [/IMG]
Noctua states that the case needs good cooling (when using nh-l9i) in order to handle CPUs with higher TDP than 65W. The i7-4970 is 88W. But I have seen many reviews for this cooler where they even used a 95W CPU.
With that said, I just got the l9i myself, and plan to use it with the same CPU. I don't plan to overclock, and I plan to disable the turbo boost if needed. The raw 4 GHz speed offered is plenty for me, and if the CPU overheats, can always lower the multiplier a little. In worst case, get a better cooler later.
I got this cooler because of it's small size and good acoustics. It was cheap too.
From my understanding it would be best to do it in reverse (in m1 case) as it would get the hot air outside of the case ...
Fans don't pick out just the hot air and leave the cold air behind. They just move whatever air is in front of them.
Heatsink works best when it's getting freshest air possible. Preferably from outside the case. This will get the best CPU temps.
Your 'reverse' idea is not so great. Air from the motherboard area will be warmer and not cool the heatsink as effectively as fresh air.
Best thing to do is try it yourself. Measure temps with both orientations. Then you will see it with your own eyes and that's better than reading a theory.
So I apparently made a mistake on my build here. I have been sitting on a H220 cooled system for a couple of months because I simply haven't had money to finish it. Long story short I finished the system, filled it up and was setting up to let it leak test. I shut off the rig after letting it run for maybe 30 seconds to move the whole system. PSU started squealing and then I hear a pop and some magic smoke. Upon evaluation it looks like I blow a nuvoton 3941s which is what powers the fan headers. Looks like it blew on pin 2 which is voltage in from the board. I bad my 2 Cougar fans on CHA_FAN1 and the H220 pump on CPU_FAN1.
Has anyone else run an H220 off of a Z87e-itx header without issue? I'm super bummed to have this issue considering how long my M1 has been relegated to a spot in my closet while waiting. I'm considering whether or not to RMA the board or just solder in a new component myself.
