Just a quick question about tracking.
Ordered V2 on june, my tracking number is CC266954839TW, no activity for about 2 weeks.
Is that normal or am I just impatient?
Try the tracking number with your domestic national carrier. If it doesn't pick up anything, email info@ncases.com and check there hasn't been a digit transposed in the tracking number.Just a quick question about tracking.
It's just slightly larger than the inner box. i.e., not big at all.Small question, does anyone know the size of the box the case is shipped in? Want to know if it's the sort of size I want to be picking up at the depot or not.
The spreadsheet is a good representation. Total orders show about 2x for the ODD option. The gap is slightly narrower with silver, but black is almost 2x on the dot.No, judging by the statistics tab on the NCASE spreadsheet, it was roughly 50/50 with the V1, but the V2 currently has twice as many ODD users as non-ODD users. Necere or W360 could probably give us a more accurate number, but going by the spreadsheet, there are more ODD users than non-ODD.
It might be. What country are you in?Just a quick question about tracking.
That does seem high, but then I haven't kept up on what's normal for that CPU.Only issue has been bleeding my H220 loop with my GPU in there. I did tight tubes so it was impossible to have a good amount of vertical space between the radiator and the other components. The fairly loud CPU cooler and the sound of water when I tilt the machine is letting me know there is definitely air trapped, but I've tried shaking it for three hours and let it run by itself overnight. I'm getting pretty high temperatures in the mid-50s at idle with my i7-4790K, but I've yet to stress test. Suggestions?
I can pretty much guarantee the H220X won't fit. As far as H220 alternatives, there's the Coolermaster Glacer 240L (essentially a rebadged H220), and the Fractal Design Kelvin S24.So... The new Swiftech H220X seems like a really tight fit, if it fits at all in a M1, so that got me wondering if there are alternatives to the H220 (without the X) in terms of 1) powerfull pump so you can expand and 2) adjustable tubes.
Are there AIO watercoolers like it, or should I start buying H220's in bulk ?
The Zalman isn't going to fit. Tubing is already very tight with the H80i (38mm thick). See the discussion starting here about thicker rads in the M1.I have some questions on cooling scenarios: Has anyone fit a 52mm thick AIO radiator + 25mm fan into the M1? I'm specifically talking about the Zalman LIQ-320, which I currently have two of in my mATX build.
I looked on the spreadsheet, and the closest thing I could find was the H80i + 12mm fan, which would get me to 50mm, and I know I can dremel off the back/"pull" fan mount if I needed those few mm. However, I'm more concerned with potential tubing routing/space issues.
Alternatively, NE has a refurb Corsair H55 for $28, but I'm looking for a quiet, undervolted build (I have a choice between a 4340 or 3570K), so I might just run on air if I got with a power-sipping CPU.
Do you guys think a Zotac GTX 680 Amp edition will fit in this case?
Side shot of the heatpipes sticking out the top: http://www.xbitlabs.com/picture/?sr...force-gtx-680-amp-edition/04_zot68_fr_big.jpg
With heatpipes like that, no way.
Even this card doesn't fit: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121803
(look at 4th picture, with the shot of the back)
I don't suppose anyone has traveled on an airplane with one of these machines in their carry-on? It seems small enough to fit. I figure water cooling is a no-go if you plan to do this, but would you have to disassemble anything else if it's in your carry-on where only you are handling it?
M1 GPU size limitations said:Max width:
- For cards up to 12.5" or cards in the third slot: 4.4"
- For cards up to 11.5" in the first or second slot: 5.5" (4.7" at the PCIe power connectors)
Dimensions
11.2 " x 5.7 " x 1.5
Dimensions
Be careful - pictures can be deceiving. The ASUS card has a taller PCB and cooler, which throws off the proportions; in actuality, the Zotac is smaller despite the apparent large heatpipes:With heatpipes like that, no way.
Originally Posted by Frozen-Q
We have made quite a few changes to improve them. These changes we're introduced in the last batch. (We only run about 12 at a time).
Below are the changes:
- Flat counter bore for the screw holes to prevent pressure from cracking out sides of face plate
- Consistent type of shallow fill plugs, we had an issue where some were too long causing them to conflict on the bottom and not seal properly
- Custom o-rings sized more appropriately for a better seal on the face plate
- Internal machining done using a better type of end mill which has been leaving a much smoother finish.
All orders come from the new batches. Like I said, we do them in runs of 12. The last few runs have been the revised type. Any orders placed here on out definitely will be.
I doubt you'd have to remove the side panel or have it swabbed. X-Rays penetrate your aluminum laptop just fine, they'll go through your desktop too. Thought perhaps not quite as well given the increased thickness. I've never seen them have someone disassemble something they're carrying to swab it, usually it's just the person's hands or the bag.Doubt you'd have to disassemble it but you'd have to let security take a look inside and xray it without the side panel, then wipe a cloth/glove all over it to check for explosives (possible static discharge). Not something I'd be doing myself.
Please check the specs!
From the compatibility section of our website:
ASUS R9 280X Direct CU II product page:
ASUS STRIX R9 280 product page:
Both of these cards also have significantly taller PCBs than normal, which means they wouldn't fit even without the overhanging cooler, due to the PCIe power connectors not having enough space.
(Scaled to the PCIe connector and bracket)
Assuming the 4.92" height is accurate, the Zotac should fit in the M1. The PCB is normal height, so the power connectors won't have any issues. The extra half slot thickness should be fine as well.
Most manufacturers exclude the bracket from the measurement, which is how I'm measuring it. You're right that not all do it this way, though. What's worse is that some give the measurement only for the PCB - not including any heatpipe/cooler overhang. Makes it practically worthless to even list in those cases. Luckily the majority seem to have settled on PCB+cooler height.just to make a point on this - which height measurements are you guys using for this? from the bottom of the PCB or the bottom of the pcie bracket?
different card makers use different measurements for their cards - for instance my XFX 290 DD is measured at 5.63 inches - which shouldnt fit - however its in my M1 and fits with probably almost an inch to spare (see my link to my build on OCN). this is because xfx are including the PCIE rear bracket in thier measurement, which adds significantly to the overall measurements.
http://xfxforce.com/en-us/products/...9-290-double-dissipation-edition-r9-290a-edfd
just top clear this up - cards will fit over the 5.5 inch height if the manufacturer includes the bracket in its height measurements.
W360 has some. Email him at info (at) ncases.comNecere, is it possible to order the plastic clips that hold the panels to the frame? do you know whom i should contact?
Just what it says on the site: 9/22 + 5-10 days.If I ordered one now, when would it arrive? (I'm in NY, USA) The site says it'll ship on 9/22?
Start reading the Builds topic and work out a build, that's also "work"I have a very distracting package sat next to me at work. Not sure how I'm going to get any work done today.
Some good news about FrozenQ res (from OCN http://www.overclock.net/t/1214130/ocn-frozenq-reservoir-owners-club/1820):
Be sure not to overtighten, as this is aluminium. You'll shred the thread right out.
