This was accounted for. The only part that had the potential to conflict is the PCI retaining tab, which was also moved down.
Thanks good to know.
Ordering through the website is pretty barebones currently, and as such there is no order confirmation besides from Paypal. As long as you have that though, you can be sure we have it on our end.
Yes.Well, I got the message from PayPal, that the money was transferred to the Ncase Account - I also have an transaction number. So you say, that this is all I need to do and know, can relax and wait for the case to be delivered at the end of September?
To illustrate, see the following non-exhaustive list of mini-ITX cases:
UK folks: Looks like they're using Parcelforce for our end of the delivery, I punched in the CC tracking number and got an ECxxxGB number on the Parcelforce site. Latest two updates are below:
18/8/2014 10:21 National Hub Received and processed
18/8/2014 1:59 International Hub Revised charges to be paid
I was assuming they'd attempt to deliver and shake me down for ~£26 or something, not sure how they'll handle it. Probably going to be an attempt tomorrow for me. Anyone else, try putting the original tracking number into http://www.parcelforce.com/track-trace and see what happens, maybe give parcelfarce a bell?
Looks like you can pay the import duty online:
https://www.pfwcustomercontact.co.uk/PCIAPSPublic/
I'll give it a go when I get home.
Only those people that got air shipping from Taiwan got tracking numbers, because those are the only cases that have been shipped to end users.Tracking info? Do those who order the current ones get this? All I got was the Paypal confirmation and such.
The rest of the cases are on a ship on their way to the US, scheduled for arrival sometime later next month. At that point, w360 will be shipping them out to end users and tracking will be available at that time.
US air shipping = from the US to anywhere in the world by airI see, thanks for clarifying that. Does the tracking info apply on a later date even to those who had to use US Air? And how do we receive the tracking info? E-mail? PayPal?
US economy = ground shipping within the US only
Both shipping options will only start when the cases have arrived in the US (late Sept.).
Understand, as soon as the cases were manufactured they needed to be shipped out from Taiwan - they couldn't be held there. So people that got orders in before August 4th had the option of air shipping direct from Taiwan. The unclaimed cases, along with US economy orders, got put on a cargo ship to the US.
W360 will update tracking in Paypal once those orders start shipping.
And its a slow boat too.Last time didn't someone have a way of tracking the boat as it made its way across the ocean? I seem to remember something about that.
Btw I'm going with the 4790K for my build and was thinking of cooling it with a Noctua NH-L12. Any better choices for air cooling, or will it do nicely?
Have you considered using an NH-C14? I'm assuming that you'll need VLP ram, but you'll need a motherboard with a well-placed socket so that the C14 doesn't interfere with your GPU. Also, if you're going to go with the C14, you most likely won't be able to use the 92mm fan on the back.
60x50mmWhat is the height of the reservoir tube in this sketch? 50 or 60mm?
On the bottom of the case, like in the pic? You should be aware that there may not be enough vertical space under the GPU. The Koolance DDC top is 26mm tall, for an overall height of 48.6mm, plus ~2mm for a plug for the top inlet, so ~51mm total. The space you have will depend on which GPU block you use. The one in the model is a 13mm thick EK block and leaves ~47mm.I am thinking of adding koolance base with ddc pump.
Why do you think that? The models are accurate to the published specs, and the fittings do approximately line up to the watercooling holes. And there's enough room for the tubing to bend to accommodate any offset between them.And mount the reservoir just like in the picture. But i think the reservoir need to be a little further up to allow the tubing to pass through the hole.
So the side panel kit comes with both sides, front and top panel w/ ODD slot?
Is there any way we can order a side panel kit with a top panel w/ no ODD slot?
And a side note for UK people, just got the letter from Parcelforce and they want £26.02 (£18 to the tax man and £8 for themselves).
Just a quick thought for future runs, but do more people not order it without the ODD slot and therefore the panel kit would be better as side panels and the top panel without ODD slot.
60x50mm
The top in the model is the Aquacover DDC, which is 6mm shorter than the Koolance and should (hypothetically, anyway) have just enough room. But again, it depends on how thick your GPU block is.
Then again, if you're talking about mounting the pump+res to the back of the case, that does change things. Checking the model, I think it would be too awkward tbh. The ports on the the pump top are offset to the right of the watercooling holes, so a custom mounting bracket would need to be fabricated. The pump itself also extends down and partially block the GPU connectors in the first slot. I think a bottom-mounted pump and rear res is the easier option, as long as you're careful with component choice. There are a couple builds in the gallery with this setup.
Just a quick question about tracking.
Ordered V2 on june, my tracking number is CC266954839TW, no activity for about 2 weeks.
Is that normal or am I just impatient?
