It probably is 5-6 years old, so not that old. It's still a high end case (5mm walls) but some of the features that modern cases have such as a hole in the motherboard tray are missing.Floppy disks, Zalman... I feels like I just went back to 1994
Special setup, you are also doing some DJ'ing there ? The TV seems odd in the corner with a speaker in front of it. Your monitor also seems slanted. Sorry, it's my OCD getting the better of me
I
Thank you for sharing Rezot! I just saw your post it would have saved me a lot of time. Such a brilliant log! But I did learn something tonight - how to read instruction manuals for the first time. And thanks to everybody who put up with all my noobie questions and helped me get this far
Rezot, nice build! How is the noise of your build at load? What CPU cooler are you using?
Nice, thanks for the comparison pics. I moved from a PC-Q11, too, but was able to get everything (full ATX PSU) in as I happen to have a MSI GTX 760 ITX version (the short one). It comes in handy. Only letdown is that I had to cram in my second SSD behind the PSU as there was no other place to mount except for below the GPU which I didn't want to do due to airflow (main SSD is in ODD hold).
I've got a full-sized ATX PSU, that won't fit I think. Nevertheless it works this way.What about mounting both SSDs on the front behind the front panel, that's what i did and just brought a external DVD drive if i find i never needed to use a DVD which I've used like 4 times in the past year .
It's a Noctua LH-N9i
As you can see, temps aren't great, but they're not horrible either tbh[for an air cooler].
And here they are under load.
I'm looking into ordering an M1 but I can't for the life of me decide which motherboard to get: The Z97 Asus Impact or the Z97 Evga Stinger. I much prefer the looks and features, rather lack thereof, of the Stinger but I don't know if they finally got their BIOS business straightened out. The Impact is bascally a safe bet but I really hate its looks.
Is anyone here using an air cooler and the hard drive bracket and having problems with temps? It seems like a lot of heat is coming off of my GTX 780 Ti and is creeping up on my Noctua C12P SE14 and my hard drives.
Anyone have any suggestions for reducing the temps? Its also pretty freaking hot right now in Southern California and I feel like it could also be that.
Sell 780ti and buy 880
Is anyone here using an air cooler and the hard drive bracket and having problems with temps? It seems like a lot of heat is coming off of my GTX 780 Ti and is creeping up on my Noctua C12P SE14 and my hard drives. Also, does anyone have a 3.5 hard drive under their gpu? If so, how are the temps of the drive?
Just curious are there any plans on them making a MATX case?
They said they were going to, unless one more person asked about it - in which case, they would scrap those plans forever.. nice job
And no.. there aren't any M1 mATX plans that anyone knows of. I'd recommend following Aiboh's current concept, though. Probably the next closest thing..
http://hardforum.com/showthread.php?t=1816110
Just posted my V2 build log in my original thread if anyone's interested
It looks really great. Good job on the build!
CheersNice build any reason you faced the PSU inwards instead of facing out?
If you are having trouble with stability, try flipping the PSU around first. Since you are using the 600W and it should be tested in hot-box environments (40-50°C ambient), it shouldn't be a problem for the 300-350W draw you have. Also keep an eye out on your HDD temps, they shouldn't exceed 50°C (45°C is a better comfort zone).I was advised this is the best way to face the fan for my setup, but I am new to this so all advice welcome... do I understand this right: the H60 is intake so the PSU sucks hot air out if the fan is inside? And GPU is blower/exhaust
They seem to have abandoned it when M.2 became an option with Z97. In my opinion M.2 is the better choice in the end, but I see the issue when you have an mSATA drive. If no board pops up with mSATA, this might be a "solution": http://www.newegg.com/Product/Product.aspx?Item=N82E16812186184is there any other mITX motherboard with mSATA available? i have a ASRock Z87E-ITX, but it seems to be the causing a lot of headache for me, and the Z97 version doesn't have mSATA. i already have a mSATA SSD drive, and i don't want to go the M.2 route.
Will do, cheers. So I should leave it as is unless having trouble? Haven't had the chance to stress it yetIf you are having trouble with stability, try flipping the PSU around first. Since you are using the 600W and it should be tested in hot-box environments (40-50°C ambient), it shouldn't be a problem for the 300-350W draw you have. Also keep an eye out on your HDD temps, they shouldn't exceed 50°C (45°C is a better comfort zone).
Hi there,
I recently ordered the ncase m1 v2 and payed via PayPal. After the payment process I was returned to the ncase website, but I missed a "order confirmation" information. It just was the regular website. I have already emailed to support@ncase, but didn't receive an answer, if my order is placed or not. Did someone of you experienced the same behaviour of the website?
Thanks for the tips mate, will give it a test run in the next few days when I finally get to install a few more things on thereIf you have the time and motivation to test it, I'd suggest testing it with running Heaven Benchmark for 30 minutes in both setups, leaving an hour of idling in between, to assert the temperatures. Note the max temperatures on the hard disks, CPU and motherboard chipset, also listen for the PSU's fan and if possible, use a thermometer above the PSU exhaust (not touching the grill prefereably) and see how that goes. Mind you that the component's temperatures are influenced a lot by the panels on the case being on or off it. Especially the top panel influences the PSU's temperature after a while because hot air seems to be restricted by the top panel. So measure with the panels on.
I would guess with your current setup, the PSU will be warmer, but your CPU and HDD's will be cooler. If you flip it around, with the PSU fan outward, I expect the CPU and HDD's to be warmer, but your PSU to be cooler. This is a guess though, I could be completely wrong if the airflow isn't how I think it is or I'm forgetting an important factor.
any1 wanna buy my ncase v2 silver, let me know i still haven't open the box yet. i'm only selling because i don't have the money to build the system atm. only shipping to australia btw.
Move rear 92mm fan and tubing holes down 2mm
Ordering through the website is pretty barebones currently, and as such there is no order confirmation besides from Paypal. As long as you have that though, you can be sure we have it on our end.Hi there,
This was accounted for. The only part that had the potential to conflict is the PCI retaining tab, which was also moved down.Question does the Frozen Res fit the M1 V2 reason i ask is because of this change below?
