Maybe I'm just being pedantic - but he is saying "should" and "tricky" in that thar quote.
what would be interesting is a second radiator under the gpu, because for water cooling card and cpu a 240er radiator would be to small.
wont fit am atx psu with the radiator right?
from the OP: "logo will be a sticker included in the box - apply it anywhere you prefer"
Hmm I don't think a dual 120mm rad will cool a high end gpu and cpu if you want to OC...is there room to put a 120mm rad on the bottom, I think a dual 120mm rad wouldn't fit on the bottom depending on the port configuration of the GPU.
but an only 30mm thick radiator, too? Perhaps a 50 oder 60mm could handle this but there is space for a slim one and thats why i think that wouldn't be enough or it is enough but then you have a turbine next to you^^
A copper 240 rad will cool any current top end mildly overclocked CPU+GPU just fine. At least better than the stock air coolers will.
oh that sounds good ... i only had an 480 radiator in my old TJ07 for Board, CPU and GPU. Thats why i thought it would not be enough^^... Thanks for your quick reply!!
@Necere
what´s the maximum possible length for the bottom radiator ?
people end up using multiple 240 radiators when really a single 120 would suffice. make it a thick 120 with a medium speed fan
would it be possible to get a picture directly from the top? So i can imagine how much space is there between the cooler (Noctua NH-C14?) and the fan? Perhaps the Phanteeks PH-TC14S could fit.
Dimensions without the top-fan: 145 x 113 x 140 mm (B x H x T)
Necere already gave us the spec and wahaha added it to the first post: 105mm CPU cooler height
I assume that you could run without the fan cage installed and get a little extra height, 25mm-30mm more? so the Phanteks would be really close, if it fits at all.
NH-C14, 105mm without fan? http://www.noctua.at/main.php?show=productview&products_id=37&lng=en&set=1
I assume the gap to the mounted fans is not large...
In the renderings, Necere used a NH-C14 and specifically said that it could be possible as long as the motherboard's CPU placement is perfect.
My AX120 has a core of only 21mm and is able to keep my i7 under 50C loaded on its own, and under 60C if the GPU is also loaded. Using Noiseblockers at ~1000-1300 rpm and pump at 30%, my loop is still quieter than my PSU.
All it needs to do is keep the CPU at around 60, the GPU temps won't matter at all as they'll be vastly under what any air solution can offer. What you care about most in that situation is not having jet engine blower fans running 100%, that's pretty much the main reason to WC a gpu.
Also can 2 single clossed loop watercooling units be fitted? IE H60/H80/620 idea is cpu can be WC'd and then via Dwood bracket the GPU can be cooled
Wouldnt you run into clearence issues if you wanted to put the pump on the gpu and radiator right under it?
If you can barely fit a slim radiator and slim fans, I cant see it all fitting, plus it'd probably be same cost or cheaper to build a cheap custom single loop...
