Have you heard any clicking noises coming from the noiseblocker in the psu? I am getting the PSU and am wondering if the fan mod is worth it. In the PSU mod thread I thought I remembered a few guys mention the ticking noise and if that counteracts the noise reduction of the swap it seems kind of pointless to go through with it.
Have you considered hiring a fulfillment company in Taiwan so you won't have to deal with the physical boxes anymore? I have a feeling people will be more than happy to pay a little more for that.
Did you guys just get the adapter and plug it in or did you solder ?
Any clues to whats different?
How about sending cases to review sites before you start another campaign. I'm sure you'd get loads of requests after that and it'd be interesting what reviewers thought about it.
Ugh, nuts! Countersunk hex screws would be a good compromise, no?
Yeah, I'd be much happier with hex screws.
My only reason for wanting nuts, is to avoid the chance of ever damaging the threads on the case and brackets (using wrong screws, cross-threading, or heads rounded too badly). Would definitely be a "fiddly" solution, but for the most part, shouldn't be impossible to install (not sure about the mainboard mounts.. don't think they'd be accessible for nuts with the current design). But yeah, really didn't think anyone else would like the idea
And as I was asked about how I power the PSU fan, here are a few photos that somewhat illustrate how I did it. Not the greatest, but its there.
This first photo shows the original fan cable. I snipped it at the base of the stock fan, leaving me with some wire to use. I did not bother with playing around with the PSU fan connector and finding an adapter because the stock 80mm fan was going straight into the spares bin. I threaded this wire through the little hole above the middle modular connector and then soldered a 3 pin 0.1" pitch plug to the power cables. This is a standard connector normally found on your motherboard.
http://www.altronics.com.au/index.asp?area=item&id=P5493
This second photo shows where the plug comes out. Ideally I should have made another hole for it to pass through, as this disables the ability for the middle modular plug to be installed, but I was not going to be using this one so it was not a concern. I was more keen to get this PSU up and running first.
In this third photo, this is a more recent one where I have increased the fan hole to suit a 92mm B9 fan. The connector is visible here, except I have also added a larger heatshrink to help insulate and protect the exposed connector pins when no fan is connected. Last thing you want to do is short out these pins and fry the internal fan controller circuit. Also note that there is the main power cable from the PSU, and then an extra wire that comes out. This is the third wire, the RPM sense wire which goes to my motherboard header, so I can monitor the RPM of the PSU fan. Lets me know what the PSU is doing.
i also didn't like the thin panels, but i understand that was a limitation of the manufacturing process.
I'd be more okay with the thin panels, if they were the style that slide into place and then are each held at the back with a couple thumb screws (or even the smaller screws).
Popping on and off such thin panels only increases the chances of them getting bent or warped.. a conversion to sliding panels would also eliminate the issue of plastic clips breaking (though the front panel might still be better off as a pop-style).
Right. The way the case is designed doesn't lend itself to that type of attachment method.Sliding panels would necessitate folding the panel edges over. It would take away the nice and sharp edges we currently have. The area where the front cover meets the top would also be a nightmare.
Yeah, it's one idea I've had. There are a couple issues with it though: the welded fixtures to attach the aluminum strips to the inside of the panel protrude 5-10mm, which there currently isn't clearance for all around; there would need to a folded tab on the back end of the panel to screw it to the case, and the back of the case has little space available.Instead of increasing M1 dimensions any, perhaps encroach slightly into the open parts of the interior (a few mm) using another piece of aluminum bent and tacked to the inside of the panel to reinforce them. Maybe similar to the inner reinforcements added to car doors, hoods, and other body panels?
I have a list of minor improvements (including the one you mention), as well. But nevertheless, I want to at least make an attempt to address some of the more difficult issues. We would need to have an updated sample made to confirm the changes before proceeding with a full production run, of course.I'd suggest minor improvements, like correct length screws for the SSD stack pieces. Doing major overhauls could turn into problems.
Yes, and the number I had in mind was higher than that, even.On the topic of screws, maybe at least 7 screws instead of 5 for the 2.5" HDD mounting screws, would be a better number for those who intend to mount 2.5" drives on both the inside and outside.
edit, im sure this is one of those things on your minor adjustments list!
I'll make a note of it.While we're on the topic of rev 2 wishlist items, I hope you don't mind:
1. Remove the top panel screw (at least for the no-ODD option). I personally never came close to lifting the M1 near the top.
This is very unlikely, and I doubt you'll find many people would want this. Assuming some method of attaching the whole piece could be worked out, it would be massively less convenient than the current method.2. This is a lot more far fetched - but maybe there's a way it can be done. I'd like to see a one-piece, U-shaped side/front panel option. With the line between the side and front panels gone, the vents can extend forward a little.
I'm not sure how great the demand is for it, but I'll make a note. I'd probably only want to do it on cases with silver panels, though.3. Last but not least, non-painted frame and hardware. It's just too easy to scratch the black finish on both the frame and the hardware.
Screw holes for 3x80mm fans wouldn't play nice with the bottom drive mounts, unfortunately. You think they'd work better than 2x120mm?I think it would be nice to have screw holes for 3x80mm fans at the bottom to imitate the 3xGPU fans found commonly in non-reference GPUs nowadays. If that is at all possible.
Why do you want the vents to extend forward, out of curiousity? The only thing I can think of is to reduce the blockage of the ST45SF-G intake, which honestly doesn't seem like a big deal to me (it's, what, 20% blocked or so?). Also, by the time rev 2 production rolls around, Silverstone's updated SFX will likely be out, which has the fan moved back to the center (assuming the pics on Enhance's site represent that model).
80mm fans might possibly yield better temperatures.
It's possible, but I really don't see how 3x 80mm fans could be any better than 2x 120mm as bottom exhaust (possibly more focused as intake). With 3x 80mm, it's also possible that the exhausted heat might just bounce back up into the case through the opening beside the fans (unless dammed off). Interesting idea, but just seems like a louder solution imo. I could be wrong though.. there's always a first for everything
Most changes are going to be minor but one major change i would like is for the SFX PSU mount to be lowered just a tad and a 80mm fan mount added over it, I have my whole system under water but that doesn't stop my PSU from overheating after long hours of gaming, They create way to much heat and have no way to exhaust it well enough, I've looked into ways to add the 80mm fan but don't feel like cutting up my M1.Necere
All this talk about changing the panels to avoid bending and broken clips has me wondering how people are actually pulling their panels off. I always do mine from the long edges of the panels and they pop off really easily with only a small bit of force.
it's one of the things I'm looking at addressing for rev 2 of the M1.
