parts:
http://pcpartpicker.com/p/2YJtD
pictures:
question: what are good softwares to stress-test the CPU, memory, and GPU? i'd prefer if they're free. i'm running at stock clocks now, to make sure everything is working as it should.
- Is that the same board I have? (Asrock Z87E-ITX)
- Where'd you get the custom PSU cables?
If it's the same board, you should put that mSATA port on the underside to good use! I haven't explored the BIOS, but I hear that Z87 chipset boards (even Intel's) have a feature to use an mSATA SSD as a dynamic cache drive...effectively working together with your mechanical HDD as if it was a hybrid drive.
I mounted my PSU the other way (like it shows in the renders on ncases.com), especially because I don't want it sucking dust into the system. I wonder if I can mod it to turn the AC socket around without turning the entire PSU. :hmm:
