GutspillerX
- Jul 11, 2013
NCASE M1 DEMCiflex filters are now live and available to order..
http://www.demcifilter.com/c220/NCASE-M1.aspx
You can use either, it doesn't really matter at high or low flow rates. I was planning to use the 'right' side as intake initially, but I found it better with the Asus Impact configuration I went with to use the 'left' side as intake. It gave me a little more room for the expansion slot and less crossed tubing.
Thanks for the info! I'm using the Gigabyte H87 as well, but mine is just a beginners build. I'm extremely happy with it, but would eventually like to fine tune it for noise and cooling. I'm not interested in overclocking, so was glad to see your build. Let us know if you find ways to improve your load temps. I wish this forum had a Gigbyte MB thread (like they have for some of the ASUS and Asrock itx boards), as I have a few questions and Gigabyte is ignoring my emails.The cables are the silverstone PP06B series...
For the H87N-WIFI it was much easier keeping things clean and tidy with these cables than it was with the stock cables that came with the PSU.
Yeah, I hear that. The planning and building part was fun. I wish there was a place I could go muck about practicing different builds without having to spend mega-monies on parts.... and the second is that now that the build is finished i've got nothing to work on
Anyone else with the Z87 Deluxe having these WIFI issues?
Having a lot of trouble with the WIFI on my ASUS Z87I-Deluxe board. Specifically it recognizes no wireless connections available. This is while running Win 7 Pro 64 bit. The weird thing is that for a short time I had Win 8.1 Pro 64 bit installed and the wireless worked fine.
I had to revert back to Win 7 due to constant blue screens and GPU crashes.
Just wanted to add that I've done multiple clean installs of Windows as well as the Broadcomm drivers for the wireless card.
I emailed them last week. They said they have an order in with Lian Li and they should get them sometime early/mid February. I'm totally going to try to get a bag of them. I see myself using this case for the next decade or more.
Check out the Newegg reviews on this board.. only negatives seem to be with WiFi issues and/or failure of the WiFi module.
Might be a pain in the butt, but you could reinstall Win 8 again, just to verify that the WiFi is still working and didn't just coincidentally crap out after you switched to 7.
EDIT: 2x wires don't seem to be specific to either port. Also, check in the BIOS that Wi-Fi controller is set to enabled.. maybe check the status LEDs by the antenna connection.
Mine does the same. But only after windows goes into sleep mode. Unplugging the PC for 10 seconds resets the wifi module.
That's great new. Yeah I'll buy enough to replace all of them just "in case"... i'm so funny....
I've got it ripped out of my rig at the moment cause Newegg was going to RMA, but they won't since the Thermaltake CLC backplate I had on there ripped a piece of the serial number sticker off.
Same here. I'll buy any spares W360 can get his hands on.. extra plastic clips, screws, rubber washers.
Nice. I still shop there, but Newegg is teh suck incarnate
Even if the status lights are working, I'd still check the BIOS to make sure it's not disabled or something goofy. Also, you can get a pair of RP-SMA 2.4/5GHz antennas for around $5 (or maybe borrow one from a router).. wouldn't hurt to rule that out.
Also, shot in the dark.. double check that you didn't install the Win 8 wireless drivers again when you went back to 7. And for the hell of it, maybe update the BIOS firmware.. new one just came out today.
FYI: Because I installed a more power hungry video card in my build, I also chose to install a 140mm power supply (SeaSonic S12G-750 http://www.seasonicusa.com/S12G.htm ). The AC inlet orientation of the SeaSonic S12G-750 precludes use of the internal right angle connector 18/3 AWG power cord that is provided with the M1 NCaseand I wanted to use the more robust 16/3 AWG power cord that came with the SeaSonic S12G-750. You can purchase more robust power cords with IEC 320 C13 left or down angle connectors from retailers, such as: http://www.stayonline.com/5-15-c13-angled-cords.aspx , but the molded IEC 320 C13 connecters typically have a height of 39mm, and thus, are too tall to fit in the available space between 140mm power supplies and the top of the M1 NCaseeven when plugged into the power supply. To solve the height interference problem, I chose to use a rewireable IEC C13 connector, namely the Schurter 4012 http://www.schurter.com/Components/Connectors/Cord-Connectors-rewireable/4012 ; or 4300-6 http://www.schurter.com/en/Components/Connectors/Cord-Connectors-rewireable/4300-06 . I cut off the molded IEC 320 C13 connecter, rewired the 16/3 AWG power cord to the Schurter connector, and then, instead of attaching the cover or lid of the Schurter connector, I wound electrical tape over the exposed wires and screw terminals. By refraining from using the cover or lid of the Schurter connector, there is plenty of clearance or room between the M1 NCase cover and the top of the Schurter C13 connecter.
Reporting in from the Netherlands... without damages I might add upon first inspection!
(Who knows .. maybe Murphy decided to give me a break!)
Silver case with silver feet - Serial 0880
Black case with black feet - Serial 0113
And yet again I have to add to the cliché saying "Holy crap.. it's tiny!"
Now with electrical tape.
I thinking more seriously about opening up the PSU and inverting the PSU receptacle (IEC 320 C14 Male Plug 3 Pins PCB Panel Power Inlet Socket Connector) for the power cord. If it pops out, and can be rotated 180 degrees and pops back in, then that is the easiest solution except for warranty issue, which I don't really care about as much as safety,Thanks. If you changed my PSU to seasonic I will try something like this or try to invert psu connector (breaking warranty )
Trying to find the Silverstone ST45SF-G PSU and PP05-E cable set. Lowest price I could find for the PSU is $94.99 at Amazon, but the cable set seems to have been backordered. Anyone know where I can find them in stock at the lowest price?
FrozenCPU has 5 of the PP05-E sets in-stock right now. Newegg emailed me a few days ago that they got some, but they didn't last too long. Personally, I'd just order them through Amazon, since they've been shipping them out early to existing orders (even when it was still showing a 2-4 week ETA). Just don't order them with something else that's out-of-stock (ie, CP11 cables), or it will hold up your entire order.
Seems like Silverstone can only manage to ship out a few here and there to retailers. Also, it's very unlikely that you'll find the ST45SF-G any cheaper than $95 until right before the new 600W drops later this year. Newegg had them on sale for $20 off right before the 2.0 versions arrived.. but that's the only price drop I've seen during the past year.
Didn't know a 600W version would come out this year. Might as well wait and see.
Just a friendly PSA to anyone buying parts!
Microcenter selling the 4670K for $179!
Picked one up and I'm on the way to pick it up!
http://www.microcenter.com/product/413251/Core_i5_4670K_34GHz_Socket_LGA_1150_Boxed_Processor
Anyone tried the Hyper 212 EVO on the AsRock Z87E-ITX to see if it fits in the M1?
I thinking more seriously about opening up the PSU and inverting the PSU receptacle (IEC 320 C14 Male Plug 3 Pins PCB Panel Power Inlet Socket Connector) for the power cord. If it pops out, can be rotated 180 degrees and pops back in, then that is the easiest solution except for warranty issue, which I don't really care about as much as safety,
I was too late to lay my hands on one of the M1 cases so I desperately built one out of a Cubitek Mini Cube.
It turned out to be OK!?...
Turned out pretty well
Does anyone have any recommendations for a quiet GPU around $250-ish (thinking something like a gtx 660 or 760). I know blower style tend to be on the louder side, so I don't mind non-reference designs.
imo
Thanks for your input! I also asked on jonnyguru and Oklahoma Wolf said "In this unit that would not be a trivial undertaking".Flipping the inlet on the Seasonic is going to be extremely difficult.
You can see in the pics here: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story5&reid=326 that the inlet is soldered to a small PCB along with the power switch and some other stuff.
I think that means I need to figure out something other than that, lol.
